kender
Compiler doesn’t catch the error. Bug? |
Posted: Tue Mar 25, 2008 4:04 pm |
Colleagues,
I’m not getting a compile-time error, when I expect it. This could be a bug. Take a look. I’ve declared a function to return int8, but commented out the return statement. Later, I call the function and compare the returned value to a constant.
int8
spi_read_only()
int8 i;
int8 iRet; // return value received from SPI
output_high(SDO); // the host will receive 0xFF.
for (i=0;i<8;i++)
output_low(SCLK);
shift_left(iRet, 1, input(SDI));
output_high(SCLK);
// return iRet; // this should provoke a compile-time error
int8
mmc_send_command(...)
while ( (spi_read_only() != 0xFF) && iTimeoutCount < iMAX_TIMEOUT_COUNT)
// a comparison to an output of a function that doesn’t return anything should provoke another compile-time error
PCWH 3.240
16F690 _________________ Read the label, before opening a can of worms. |
Posted: Tue Mar 25, 2008 4:11 pm |
No, this is standard in C.
This is why (for example), the 'Main' function, in a standard C program (not CCS), which normally returns a status byte to the OS, can be omitted.
Falling off the end of a function, or having a return with no value, is defined to return 'garbage' in the C reference manual, but is not illegal.
