Need help to correctly setup USB on PIC18F67J50
Goto page Previous  1, 2
DiegoGarcia
PostPosted: Fri Mar 07, 2008 4:21 pm     Reply with quote
So I forced to enable the pplen !
#bit PLLEN = 0xf9b.6
PLLEN = 1;
It works like a charm ;)
Thanks for the great help Ttelmah :D
Regards,
Diego Garcia
PostPosted: Sat Mar 08, 2008 4:26 am     Reply with quote
OK. OSC_PLL_ON, has existed for several versions. Typically, when it appeared, is not shown in the CCS 'changes' list. I'd guess about 4.060.
At least you have a solution. :-)
bwhiten
18F67J50
PostPosted: Mon Mar 24, 2008 9:24 am     Reply with quote
Diego,
I may have to move to this USB PIC from a 18F2553 to get the extra memory I need for my product.
How has your development gone using CCS on this PIC?
Does the compiler seem to have most of the functions working outside the oscillator issue you brought up here?
Thanks for any comments.
DiegoGarcia
PostPosted: Mon Mar 24, 2008 10:45 am     Reply with quote
Hi bwhiten,
For now its all working nice.
I think this topic will help you and many others to correct setup ;)
After the usb module is working its easy.
Regards,
Diego Garcia
bwhiten
PostPosted: Mon Mar 24, 2008 11:27 am     Reply with quote
Thanks for the update. Can you give me a quick idea of what other functions you have implemented, like SPI or I2C or A/D, etc. in this PIC and what compiler version you are running now?
I also wonder if the H4_SW fuse instead of HS fuse would set the PLL on for you?
DiegoGarcia
PostPosted: Mon Mar 24, 2008 11:39 am     Reply with quote
Right now I me using just the SPI, but the other features should work fine since it doesnt seens to be changed.
The H4_SW fuse works nice to but remember that you should set the PLLEN like I've done or it will not work to !
PLLEN = 1;
//The rest of your code here
Regards,
Diego Garcia
bwhiten
Cf value
PostPosted: Wed May 07, 2008 1:23 pm     Reply with quote
Diego,
What value of Cf did you use for VDDcore? I believe the value I have is too small at 0.47uF . I finally found in the programming guide a range of 1uF to 10uF. Hopefully this is why my programmer is not seeing this device at present.
Page 2 of 2
