aldinlapinig
Interrupt problem with PIC16F628 interfaced with GM862-PCS.. |
Posted: Sun Mar 23, 2008 10:48 pm |
Hi Everybody!
I wanted to interface GM862-PCS with PIC16F628 through RS232. The program that I researched and made seemed to work perfectly during my simulation with Proteus through Virtual serial ports. But when I did the project in actual, I am having a problem getting the data from the GSM module that I am using now. After several tries and researching, I'm no longer sure if I did miss something. Here's the simplest code that I made after several revisions:
Compiler Version: 4.038
Proteus Version: 7.1 sp6
Code: | #include <16F628A.h>
#include <string.h>
#use delay(clock=12000000)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1)
#define LOAD1 PIN_B5
#define LOAD2 PIN_B6
#define LOAD3 PIN_B7
#define PILOTOK PIN_B3
#define PILOTERROR PIN_B4
#define BUFFER_SIZE 50
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
short load1stat = FALSE;
short load2stat = FALSE;
short load3stat = FALSE;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=0; //Cyclic Buffer --> wraps up overwriting the data
void init_gsm() {
printf("AT\r");
printf("AT+IPR=9600\r");
printf("AT+CMEE=2\r");
printf("AT#WAKE=0\r");
void set_sms() {
printf("AT+CMGF=1\r");
delay_ms(200);
//printf("AT+CNMI=2,1\r"); // I have the choice to let the GSM
//delay_ms(200); // module to notify the PIC if message
} // is received before I read it.
void delete_all() {
printf("AT+CMGD=1,4\r");
void read_message() { // This will read the message recieved
printf("AT+CMGR=1\r\n");
void clean_buffer() {
int x;
for(x=0;x<BUFFER_SIZE;x++) buffer[x] = '\0';
void indicate_ok() {
output_high(PILOTOK);
output_low(PILOTERROR);
void indicate_error() {
output_low(PILOTOK);
output_high(PILOTERROR);
void main() {
char on1[4];
char on2[4];
char on3[4];
char off1[5];
char off2[5];
char off3[5];
char garbage;
short message_recieved = FALSE;
strcpy(on1,"on1");
strcpy(on2,"on2");
strcpy(on3,"on3");
strcpy(off1,"off1");
strcpy(off2,"off2");
strcpy(off3,"off3");
delay_ms(12000); // Long wait for the GSM module to initialize
indicate_ok();
indicate_error();
init_gsm();
delay_ms(900);
indicate_ok();
indicate_error();
set_sms();
delay_ms(900);
indicate_ok();
indicate_error();
delete_all();
delay_ms(2000);
indicate_ok();
indicate_ok();
if(kbhit()) {
while(kbhit()) {
garbage = getc();
enable_interrupts(global);
enable_interrupts(int_rda);
do {
indicate_ok();
read_message(); // I just choose to try read for received msg at
// location SM and index 1
delay_ms(10000);
indicate_error();
if(strstr(buffer,on1)) {
if(!load1stat) {
load1stat = TRUE;
output_high(LOAD1);
else if(strstr(buffer,on2)) {
if(!load2stat) {
load2stat = TRUE;
output_high(LOAD2);
else if(strstr(buffer,on3)) {
if(!load3stat) {
load3stat = TRUE;
output_high(LOAD3);
else if(strstr(buffer,off1)) {
if(load1stat) {
load1stat = FALSE;
output_low(LOAD1);
else if(strstr(buffer,off2)) {
if(load2stat) {
load2stat = FALSE;
output_low(LOAD2);
else if(strstr(buffer,off3)) {
if(load3stat) {
load3stat = FALSE;
output_low(LOAD3);
indicate_ok();
delay_ms(300);
indicate_error();
delete_all();
next_in = 0;
clean_buffer();
} while (TRUE);
Somebody help me find the fault of the program I made. Thank you very much. The schematic?
just GM682 PIC16F628
RX -------------------> TX
TX -------------------> RX
GND
"If I'll use the PC/Hyperterminal to act as the GSM Module, the program works perfectly"
"Don't want to use hardware flowcontrol"
Any help will be highly appreciated! THank you! |
Posted: Sun Mar 23, 2008 11:50 pm |
Quote: | #use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS) |
Add the ERRORS directive as shown in bold. If the GM862 device starts
sending data before you enable RDA interrupts, it could lock up the
UART receiver. With the ERRORS directive, this won't happen.
Do this in all your programs that use the hardware UART. |
