Pic12F675 internal oscillator ...
Radistas
PostPosted: Sun Mar 23, 2008 4:13 am     Reply with quote
My program is
#include <12f675.h>
#fuses xt,nowdt,noput,protect
#device adc=10
#use delay (internal=4M) // naudojame vidini generatoriu
int16 volt;
float rod;
#define gedim pin_A4
#define aliarm pin_A5
#define resetas pin_A1
#define statusas pin_a2
void duomenys()
volt = read_adc();
rod = volt; //1k = 23 2.2k = 11 470 om = 48 5.6k = 4 4.7k = 5
} //suveikias daviklis = 74 trumpas jungimas = 190 100 om = 162
//Ishvados 0 - 5 = nutrukes, 5 - 30 = normalu, 30-150 = suveikes 150< = trumpas
void trumpas()
trump:
output_low(gedim);
output_low(resetas);
output_high(resetas);
duomenys();
if (rod>150) goto trump; else output_high(gedim);
void aliarmas()
output_high(statusas);
delay_ms(3000);
delay_ms(3000);
duomenys();
if (rod>30 & rod<150)
alr:
output_high(aliarm);
duomenys();
if (rod>150) trumpas();
if (rod>30 & rod<150) goto alr; else { output_low(aliarm);output_low(statusas);}
void gedimas()
ged:
output_low(gedim);
duomenys();
if (rod<5) goto ged; else output_high(gedim);
void main() //Pagrindine programa
disable_interrupts(GLOBAL);
setup_adc_ports(pin_A0);
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
output_high(gedim);
output_low(aliarm);
delay_ms(2000);
duomenys();
if (rod<5) gedimas();
if (rod>30 & rod<150) aliarmas();
I rewrited chip about 8 times and chip stops, not working with internal oscillator, but with external oscillator it working.
where can be a problem ?
ty.
gjs_rsdi
oscilator
PostPosted: Sun Mar 23, 2008 7:55 am     Reply with quote
i can't check with 12F675.
i test it with 18f1220. have also internal oscilator.
i get:
#FUSES INTRC //Internal RC Osc
maybe the compiler don't understand:
best regards
joseph
PostPosted: Sun Mar 23, 2008 8:02 am     Reply with quote
The most likely thing is that the chip has been erased.....
On these PICs, there is a _single_ program instruction, in the very last location of the program memory, which returns the calibration factor for the internal oscillator. Most programmers have an _option_ to save this value when you program the chip. Otherwise, if an erase cycle is performed, this value _will_ be destroyed, and the chip will then hang if you try to run with the internal oscillator.
Read the contents of the chip's program memory.
Look at the very last instruction.
If it is blank (erased), then you will need to write a value back into this location. This can be done with a #ROM statement, but the value will then no longer be calibrated, so if you want anything reasonable in terms of clock accuracy, some 'tweaking' will be needed. A search here will find the values you need to write to get it to start (many people, myself included have posted them in the past).
Radistas
PostPosted: Mon Mar 24, 2008 1:47 am     Reply with quote
Ty, it was calibration bit, i set it to 3480 and it's working.
