Delay in hours
Johnsecada
Delay in hours
PostPosted: Thu Mar 20, 2008 11:59 am     Reply with quote
Hello all
I want to ask do you have some ideas to realize 1, 2, or 3 hours delay ?
I use CCS C compiler and pic16f88.
Is it possible to do cycle which calls many times delay function. Example:
i = 0 ;
while (i<34534534){
delay(); //( the ms version of the function )
i++;
And is this the best choice ?
10x all
esa
PostPosted: Thu Mar 20, 2008 12:46 pm     Reply with quote
You can use a interrupt using timer0 or timer1.
Configure to call this timer each 100ms
In this timer increment a variable : centms++
if centms==10 then sec++
if sec==60 the minut++
etc...etc....
In the main program, create a test on minute to make what you want.
You can find a lot of code about this to make
Hope this will help you.
Regards
Eric
SherpaDoug
PostPosted: Thu Mar 20, 2008 12:47 pm     Reply with quote
Would the PIC have to do ANYTHING during the delay? Your method would work. Delay_ms(60000) will delay for one minute. looping 60 times would delay an hour. But the PIC would be TOTALLY occupied during the delay.
I would rather set a timer to count some long period I would call a "tick". Then I would have the PIC either poll or use interrupts to count ticks, and roll ticks into minutes and hours. That way each tick the PIC can check inputs to see if the delay should be aborted for some other function.
Johnsecada
plese, tell me your opinion for my idea
PostPosted: Thu Mar 20, 2008 2:27 pm     Reply with quote
10x for the ideas
my core of my idea is that :
int count;
int second () {
Delay_ms(1000) ; // delay one second
return 1 ;
void main(void){
count = 0;  // the count of seconds that are passed
while(1){
   read_from_ports(); // function that read  from ports
   if (count > 20 &&  count < 30) { // the time space between the 20s and // the 30 s
   take_desision1();
   if (count > 40 &&  count < 70   ) {
// the time space between the 40s and  the 70 s
   take_desision2();
   count = count + second(); // delay one second and +1 to count (  second returns 1  )
I want to read each second the input information and to take a decision but the decision must depend by the count of seconds that had been past.
Please tell me your opinion about my idea
Neutone
Re: plese, tell me your opinion for my idea
PostPosted: Thu Mar 20, 2008 3:41 pm     Reply with quote
Johnsecada wrote:
10x for the ideas
int count;
int second () {
return 1 ;
void main(void){
while(1){
   take_desision1();
   take_desision2();
You do not need to use delays to count time. There is a better way. Everything else follows in a better way.
http://www.ccsinfo.com/forum/viewtopic.php?t=26177
