| View previous topic :: View next topic   |
			Douglas Kennedy
				| 18C452 and PCH 3077 does input_d() work? |
				 Posted: Fri Mar 08, 2002 11:45 am     |
				<font face="Courier New" size=-1>I may have completely misunderstood the port d i/o
but looking at the assembler below  input_d() reads the latch...
but the latch is the last value output from the PIC not the value at the port
#include <18C452.h>
#DEVICE *=16
#fuses HS,noWDT,NOPROTECT,NOPUT,NOBROWNOUT
#use delay(clock=20 000 000)
.................... #fuses HS,noWDT,NOPROTECT,NOPUT,NOBROWNOUT
.................... #use delay(clock=20 000 000)
.................... main()
.................... int data;
0004:  CLRF   FEA
0006:  CLRF   FE9
0008:  CLRF   FC1
.................... while(1)
.................... data=input_d();
000A:  MOVLW  FF
000C:  MOVWF  F95
000E:  MOVFF  F8C,06
0012:  GOTO   000A
.................... }  </font>
___________________________
	Original Post ID: 3067 |
			Hans Wedemeyer Guest
				| Re: 18C452 and PCH 3077 does input_d() work? |
				 Posted: Sat Mar 09, 2002 11:54 am     |
				I just compiled your code using
#use fast_io(D) , if your program can handle the direct access
to port D it will be faster and more campact code.
.................... #device PIC18C452
.................... #list
.................... #DEVICE *=16
.................... #use fast_io(D)
0004:  CLRF   FEA
0006:  CLRF   FE9
0008:  CLRF   FC1
....................  data = 0;
000A:  CLRF   06
000C:  MOVFF  F83,06
0010:  GOTO   000C
	Original Post ID: 3084 |
			Douglas Kennedy
				 Posted: Sat Mar 09, 2002 5:06 pm     |
				Hans you must be using a different complier version than 3077
3077 gave me this.
F8c as you know is the latch so it could never if I have it right read the input at the port. The code you showed me with F83 the port would work but 3077 doesn't generate it.
CCS PCH C Compiler, Version 3.077
               Filename: C:\PICC\PROJECT\WEBSRVR\TESTH.LST
               ROM used: 10 (0\%)
                         Largest free fragment is 16374
               RAM used: 6 (0\%) at main() level
                         6 (0\%) worst case
               Stack:    0 locations
0000:  GOTO   0004
....................  #include <18C452.h>
....................  //////// Standard Header file for the PIC18C452 device ////////////////
.................... #USE FAST_IO(d)
0004:  CLRF   FEA
0006:  CLRF   FE9
0008:  CLRF   FC1
000A:  MOVFF  F8C,06
000E:  GOTO   000A
0012:  SLEEP
	Original Post ID: 3091 |
				 Posted: Sat Mar 09, 2002 9:12 pm     |
				Your are bang on target.... I downloaded it but have not installed it yet... I just chekced I used 3.075 !
Sorry abotu that. Anyway that is interesting. I think you have just established a bug, you know of of those things that got broken when something else was fixed ! PCH has had it's share of them!
:=Hans you must be using a different complier version than 3077
:=3077 gave me this.
:=F8c as you know is the latch so it could never if I have it right read the input at the port.
If that will work for you. You can do it in assembly. Just copy paste from the lst..
Excuse me if you already know this...
Something like this
#byte _PortD_ = 0XF83  // some where in the header
int data;
  #asm  MOVFF _PortD_,data #endasm
Hope this helps.
PS I'll not install 3.077 and wait for 3.078
PPS will you report this bug to CCS tech support? They don't always monitor the public board.
	Original Post ID: 3094 |
			Douglas Kennedy
				 Posted: Sun Mar 10, 2002 8:49 am     |
				Thanks Hans ...you're a great help.
The bug is reported to CCS....
I'm new to the PIC18 assembler so I was looking for a confirmation since this bug is very severe in that it prevents all port input I thought it must be me  (misunderstanding the assembler).
I did use an assembler patch like yours (actually yours is better) to get my code working.
PCH isn't perfect but I experienced a PCM to PCH conversion of several hundred lines resulting  in 1 bug albeit a severe one. Approx 1 bug per thousand lines of code...and an almost instant 2 line fix for it (I could do myself in assembler) ...good work CCS!.. light years ahead of any microsoftie experience I have had (I now wait two years before installing a new softie OS to avoid the bugs and security wormholes).
	Original Post ID: 3107 |
