WDT WatchDog Questions? |
Posted: Wed Mar 19, 2008 3:18 am |
I would like to know, How I can calculate the time-out period? my pic is a PIC16F688,I do not understand that the time-out period for each Prescale Rate.
I think:
Bit Value = Prescale Rate -->c
0000 = 1:32 -->equals 1ms
0001 = 1:64 -->equals ???????
0010 = 1:128 -->equals ???????
0011 = 1:256 -->equals ???????
0100 = 1:512 (Reset value) -->equals ???????
0101 = 1:1024 -->equals ???????
0110 = 1:2048 -->equals ???????
0111 = 1:4096 -->equals ???????
1000 = 1:8192 -->equals ???????
1001 = 1:16384 -->equals ???????
1010 = 1:32768 -->equals ???????
1011 = 1:65536 -->equals 268 seconds
Please me a good answer to this question.
Best Regars |
Guest_7068 Guest
Posted: Wed Mar 19, 2008 4:49 am |
You must note that this version of the chip has 2 scalers.
Option_Reg : This is a standard pre-scaler that allows scaling of the WDT from 1:1 to 1:128
WDTCON : This register allows additional pre-scaling of the WDT from 1:32 to 1:65536
The WDT runs off a 31 Khz Internal Oscillator, so the lowest WDT period value you get is 31 Khz /32 ~= 1ms
The default value (RESET value) is
Option_Reg = 1:1
WDTCON = 1:512
This will give you a rate: 31 Khz / 512 = 16ms
Now, understanding the CCS options is a little tricky as they have to keep the old chip and new chip options compatible. so they use the following method:
SETUP_WDT(WDT_18MS | WDT_DIV_16);
WDT_18MS --> This is the old constant which sets up the chips which have only 1 prescaler
WDT_DIV_16 --> This will mean that 18 ms DIV by 16 ~= 1ms
Now, if you want to setup the defult value of 16 ms, you will use:
SETUP_WDT (WDT_18MS | WDT_TIMES_1); // 18 ms * 1 --> This is logically close to 16 ms
Similarly, if you want to set the highest timeout period of 268 seconds you will use
SETUP_WDT(WDT_2304MS | WDT_TIMES_128); // This will actually mean 2304 * 128 = 292 seconds which is logically close to 268 seconds
So, depending on the period you want, you can do a simple math like WDT_xxMS | WDT_TIMES_X (or WDT_DIV_X), which will give you a number close to the actual value. |
Posted: Wed Mar 19, 2008 5:15 am |
Hi, thanks for your response,
I configure the WDTCON = 0x10, for the pre-escaler 1/8192 this watchdog time period is big aprox. 8seg or more. I think that the time period for 1/65536 correspond the 268sec, and 1/4096 the 1sec. I would like to know how calculate these values.
Code: | #include <16F688.h>
#device ADC=10
#fuses INTRC_IO,WDT,NOMCLR,NOPROTECT, BROWNOUT,NOPUT
#use STANDARD_IO(C)
#BYTE OSCCON = 0x8F //endereço do OSCCON register
#BYTE WDTCON = 0x18 //endereço do WDTCON
void main(void) {
float VPS,VBAT;
OSCCON=0x61; //Configuração do registo OSCCON 4MHZ, 71->8MHZ
WDTCON = 0x10; //Configuração do wdt para preescales 1:8192 >
// setup_adc_ports(3);
// setup_adc(ADC_CLOCK_DIV_16);
setup_adc_ports(3);
setup_adc(ADC_CLOCK_DIV_16); //4us por amostra
delay_ms(1000); //1s
output_high(PIN_A5);//
while (true)
restart_wdt();
Best Regards |
