I have a project I'm working on that requires me to program a PIC micro controller, but I have never done so before so I have a few questions. The PIC micro controllers I have are the 16F690 and the 16F873. I would like to program these in C to avoid the headache of assembly. The programmer I have is the PICKIT 2.
When I installed MPLAB to program the chip, it doesn't look like it came with the toolset to program these chips in C.
My questions are (before I spend any money), if I by the CCS PCW or PCM compiler, will this work with MPLAB? Also, I need to program these chips with a hex file. Do these compilers generate a hex file so I can program my chips? The compiler I have now just generates an assembly file that I cannot use.
Posted: Tue Mar 18, 2008 6:58 pm
The cheapest way to get a CCS compiler for those two PICS is to buy
the PCM "command line" compiler. It will integrate with MPLAB.
Do these compilers generate a hex file so I can program my chips ?
Yes, the PCM compiler will generate a HEX file when it compiles your
C source file.
