DiegoGarcia
Litle help to send correct chars using the PS2 keyboard itfc |
Posted: Mon Mar 17, 2008 4:10 pm |
Hi guys its me again ;)
I've done a lot of searchs and after read some documents about ps/2 interface I've made my own and its almost everything working nice.
I've founded the make and break codes so when I send the make code for numbers 1,3,4,7,8,9,0 the pc receives fine but the numbers 2,5 and 6 make the pc beep.
here is my scancodes table
const long int PS2Keys[] =
0x45, // 0
0x16, // 1
0x1E, // 2 The pc beeps
0x26, // 3
0x25, // 4
0x2E, // 5 Here beeps to
0x36, // 6 and here to.
0x3D, // 7
0x3E, // 8
0x46 // 9
the code to send the data using the pic is :
Code: | void SendChar(byte Data)
int1 stopbit = 1;
int1 startbit = 0;
int1 parity = 0;
int i;
SendBit(startbit);
for (i=0; i<=7; i++)
SendBit(bit_test(Data,i));
//SendBit(shift_right(&Data,1,0));
SendBit(parity);
SendBit(stopbit);
void SendBit(int1 Data)
const byte dattime = 10;
const byte clktime = 50;
KeyClk = 1;
delay_us(dattime);
KeyData = Data;
delay_us(dattime);
KeyClk = 0;
delay_us(clktime);
void Main()
0x45, // 0
0x16, // 1
0x1E, // 2
0x26, // 3
0x25, // 4
0x2E, // 5
0x36, // 6
0x3D, // 7
0x3E, // 8
0x46 // 9
int i = 0;
set_tris_a(0b10000000);
porta = 0x00;
portb = 0x00;
while (TRUE)
Led = !Led;
set_tris_b(0b00000000);
SendChar(PS2Keys[i]);
delay_ms(30);
SendChar(0xF0);
delay_ms(30);
delay_ms(30);
set_tris_b(0x00000011);
if (i == 9)
i = 0; else
i++;
Any tips why just these numbers are not working ?
Thanks a lot,
Regards,
Diego Garcia |
SimpleAsPossible
Oscilloscope? |
Posted: Mon Mar 17, 2008 9:41 pm |
Have you looked at your signals with a scope? The scan codes look right, according to the information I have. Maybe the clock gets skewed slightly? I had a nice theory going about strings of 1s, but 7 and 8 don't fit the theory. Sorry. Do any of the keys get misinterpreted occasionally?
I'd like to know that you got this working, since I may do something similar soon. |
DiegoGarcia
Posted: Tue Mar 18, 2008 4:45 am |
I've found what is the problem, its the parity bit it should be calculated, the way that I've done is not checking the parity bit so I've to do it !
I will acomplish this task now and after I get the right results I post it here ;)
Regards,
Diego Garcia |
DiegoGarcia
Posted: Tue Mar 18, 2008 5:37 am |
Here is the correct sendChar function
int1 stopbit = 1;
int1 startbit = 0;
int1 parity = 1;
int1 databit;
int i;
SendBit(startbit);
databit = bit_test(Data,i);
if (databit == 1)
parity += 1;
SendBit(databit);
SendBit(parity);
SendBit(stopbit);
Now it works like a charm ;)
Regards,
Diego Garcia |
