sv_shady
Problem with i2c_start() condition |
Posted: Sun Mar 16, 2008 2:49 am |
Hi I have a strange problem with the i2c bus. The pic is in master mode and should transmit data over the i2c, which is received from rs232. Here is the code:
Code: | #include <16F877A.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz)
#FUSES PUT //Power Up Timer
#use delay(clock=10000000)
#use i2c(Master, sda=PIN_C4, scl=PIN_C3, force_hw)
#define START_BYTE 0x41
int c;
int value_X;
int value_Y;
void INIT(void)
setup_adc_ports(NO_ANALOGS);
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
INIT();
for(;;)
if(kbhit())
c = getc();
if(c == START_BYTE)
value_X = getc();
value_Y = getc();
i2c_start();
i2c_write(0x10);
i2c_write(value_X);
i2c_write(value_Y);
i2c_stop();
When i use the hardware i2c the PIC receives the data from rs232, but it stops at i2c_start() and i have to restart it. When i use software i2c this problem disapears... Any ideas why this happens ?
Thanks in advance
P.S. The compiler is 4.057 |
Posted: Sun Mar 16, 2008 8:43 am |
int c;
int value_X;
int value_Y;
void INIT(void)
setup_spi(SPI_SS_DISABLED); // Delete this line
setup_vref(FALSE);
The setup_spi() statement re-configures the MSSP module.
It destroys the i2c mode setup that was done by the force_hw parameter.
To fix the problem, delete the line for setup_spi(). |
sv_shady
Posted: Sun Mar 16, 2008 1:22 pm |
Thanks a lot  |
