Union of pointer
Franck26
Union of pointer
PostPosted: Fri Mar 14, 2008 11:18 am     Reply with quote
I'm trying to use an union of pointer and I'm very not successful...
union uPointer
   unsigned int8* ptr1;
   unsigned int8* ptr2;
void MainProg()
   union uPointer uptr;
   unsigned int8 Var1;
   unsigned int8 Var2;
   Var1 = 0;
   Var2 = 0;
   uptr.ptr1 = &Var1;
   uptr.ptr2 = &Var2;
I thought that uptr.ptr1 would point on Var1 and uptr.ptr2 on Var2.
But the result is that both of the pointer are on Var2...
Do you have an idea about that?
Thanks for any help.
PostPosted: Fri Mar 14, 2008 11:22 am     Reply with quote
In a union all members are overlayed, i.e. they all share the same memory bytes. When you assigned Var2 the other value was overwritten. From your question it looks like you want to use a structure instead. Change you program by replacing 'union' by the word 'struct'.
Franck26
PostPosted: Fri Mar 14, 2008 11:32 am     Reply with quote
Thanks for your answer ckielstra,
You're right, it works fine with a structure
Embarassed
Franck,
