*SOLVED* Guidelines for including multiple source files?
ThomasC
PostPosted: Fri Mar 14, 2008 9:12 am     Reply with quote
PIC16F690-ICD / PCM 4.060 / ICD2
I get an error 128:
Error 128 "temperature.c" Line 3(1,1): A #DEVICE required before this line
When I try to take out a module from my main source file and place it in a separate source file (temperate.c) to better organize my code.
I used the include line and tried adding #device to the temperature.c file.
Thanks!
http://forum.microchip.com/forceddownload.aspx?file=0%3b322231
PostPosted: Fri Mar 14, 2008 10:25 am     Reply with quote
Only the main source file should be put in the "Source Files" list.
Don't put any #include files in that list. You can add them to the
"Other files" list.
Look at the Project window in the lower left corner of your screen shot.
You have your main file, PIC16F690.c in the list. But you also have
temperature.c in the list. Remove it. Add it to the "Other Files" list.
ThomasC
PostPosted: Fri Mar 14, 2008 10:38 am     Reply with quote
SOLVED.
Thanks for the quick response. I am literally taking notes of your advice. Thanks again.
