dsPIC33, basic program, big problem...
romelec
PostPosted: Fri Mar 14, 2008 4:09 am     Reply with quote
I am using a dsPIC33FJ256MC710, look at this small code:
   int8 ind;
   int8 tab[10];
fprintf(COM1,"test...\n");
tab[0] = 3;fprintf(COM1,"tab[0]=%d\n",tab[0]);
tab[1] = 9;fprintf(COM1,"tab[1]=%d\n",tab[1]);
tab[2] = 16;fprintf(COM1,"tab[2]=%d\n",tab[2]);
tab[3] = 35;fprintf(COM1,"tab[3]=%d\n",tab[3]);
for(ind=0;ind<10;ind=ind+1)
   tab[ind] = ind;
   fprintf(COM1,"ind=%d tab[ind]=%d\n",ind,tab[ind]);
very basic and should not cause any problem, isn't it ?
so know let's have a look at the result
test...
tab[0]=6
tab[1]=6
tab[2]=6
tab[3]=6
ind=3 tab[ind]=54
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
ind=3 tab[ind]=0
at this point the message is always the same until i reset the pic
if i use 16 bits integers:
test...
tab[0]=3
tab[1]=9
tab[2]=16
tab[3]=35
ind=0 tab[ind]=0
ind=1 tab[ind]=2
ind=2 tab[ind]=4
ind=3 tab[ind]=6
ind=4 tab[ind]=8
ind=5 tab[ind]=10
ind=6 tab[ind]=12
ind=7 tab[ind]=14
ind=8 tab[ind]=16
ind=9 tab[ind]=18
and 32bits !
test...
tab[0]=3
tab[1]=9
tab[2]=16
tab[3]=35
ind=0 tab[ind]=0
ind=1 tab[ind]=262148
ind=2 tab[ind]=524296
ind=3 tab[ind]=786444
ind=4 tab[ind]=1048592
ind=5 tab[ind]=1310740
ind=6 tab[ind]=1572888
ind=7 tab[ind]=1835036
ind=8 tab[ind]=2097184
ind=9 tab[ind]=2359332
Maybe you understand the problem, but me absolutely no Confused
using microchip C30 it works of course very well.
Do you see a solution, except migrate my program to microchip compiler ?
(I have just sent a mail et the support)
Romain.
murtis
View user's profile Send private message Send e-mail MSN Messenger
try...
PostPosted: Fri Mar 14, 2008 7:43 am     Reply with quote
hi,
this is the float print but %d is using integer print
and also, ind and tab[10] is identificated as an integer number.
May be,
you can solve the problem if you are using the code written like below
and also, you should try 'putc' command.
MurtiS
