How to : 2 questions in 1 thread about CCS capabilities...
Matro
PostPosted: Thu Mar 13, 2008 11:10 am     Reply with quote
Hi everybody,
As announced in the subject, I've got 2 (more) questions.
- How to change the location of the ISR dispatcher?
I found an explanation on CCS help (JUMP_TO_ISR) but I'd need to write my own dispatcher and I don't want to do so.
Is there a mean to keep the CCS ISR dispatcher but to change its location?
- How to change the behavior of "write_eeprom()"?
When compiled the "write_eeprom()" function launches the EEPROM writing and then waits for it to be finished.
I'd prefer that it checks at the beginning if a "write" is already in progress (and either wait for it to end or exit) and if it is OK that it launches the "write".
Is there a way to obtain this behavior without writing my own function?
Thanks in advance for your helpful answers,
Matro.
PostPosted: Thu Mar 13, 2008 11:39 am     Reply with quote
You can tell the compiler to do that by adding the #device statement
shown in bold below.
#include <16F877.H>
#device(write_eeprom=ASYNC)
write_eeprom(0x22, 0x34);
Matro
PostPosted: Fri Mar 14, 2008 2:22 am     Reply with quote
That's perfect!
Thanks for that tip. Strange thing that it isn't documented in the help of CCS...
One of my 2 question already answered.
If somebody knows the solution for the first one it can be very helpful.
Thanks again for the help.
Matro.
PostPosted: Fri Mar 14, 2008 4:15 am     Reply with quote
For the second question.
#build(interrupt=xxxx)
Matro
PostPosted: Fri Mar 14, 2008 6:24 am     Reply with quote
Thanks for that tips.
It works fine. There is just a last problem to solve.
At now my code is as follow :
#define INT_ADDR 0x020
#build(interrupt = INT_ADDR)
#ORG 0x004,0x01F
void jump_to_int(void)
#ASM
   GOTO INT_ADDR
#ENDASM
As you can imagine I have to jump from the 0x004 address to my new ISR dispatcher.
This code works but due to the fact I declare a "jump_to_int" function the
"GOTO INT_ADDR"
is followed by a
"RETLW 00"
and I don't find it very proper.
Is there a mean to place this "GOTO INT_ADDR" in the 0x004 location without having this "RETLW 00" i.e. without creating a function?
Thanks in advance for every helpful answer (and thanks Ttelmah for that big step ;-) )
Matro
PostPosted: Fri Mar 14, 2008 1:12 pm     Reply with quote
I was playing with this same question in my bootloader. A function will always terminate with a RETLW, that's why it is a function. The solution I found was to use #int_global. This places an empty ISR dispatcher at address 0x0004.
#int_global
void isr(void)
  #asm
  GOTO INT_ADDR
 #endasm
My bootloader did not use interrupts. For you there might be a problem as I don't think the above workaround can be combined with the #build keyword.
Maybe we can give you a better solution if you tell us more about what you want to achieve.
- Why do you want to make your own dispatcher?
- And why have this next to the default CCS dispatcher?
- Which chip are you using (PIC16 or PIC18)?
Matro
PostPosted: Mon Mar 17, 2008 4:24 am     Reply with quote
Hi ckielstra,
I will explain a little bit more what I need if it can help you. :-)
I don't want to make my own dispatcher but to keep the CCS one.
But I want it to be place elsewhere that in the address 0x04.
Why?...
My program contains a bootloader and I don't want that the jump to it (addresses 0x00 - 0x03) can be erased.
The problem is that I work with a PIC16F88 with which the program memory is erased by 32-byte blocks.
And finally I want also the user to be able to change the ISR dispatcher.
So I can't place it at the standard 0x04 address because erasing this address and next ones will also delete the bootloader jump.
I hope I was clear in this explanation (and I hope too that somebody could find a solution).
Thanks for your answer but it can't definitely not be OK for me. ;-)
Matro.
Matro
PostPosted: Tue Mar 18, 2008 5:23 am     Reply with quote
Sorry to up this subject but it will be a very nice thing if my question could be answered. ;-)
Does somebody know how to compile a function that never returns (like the built-in "reset_cpu()" does)?
Or eventually how to place a single ASM instruction in a specific memory location?
Thanks in advance.
Matro.
Guest_7068
PostPosted: Wed Mar 19, 2008 5:25 am     Reply with quote
See if this works for you
#rom  0x0004={0x2840}
The #rom directive will put that data in the ROM location and it will not care if it overlaps with something else. So make sure you test this fully.
The 0x2840 is the Op-Code for a GOTO 0x0040. This opcode will assume that the PCLATH is cleared which is the case after reset. I have not tested this, but I think this hack should work.
Matro
PostPosted: Wed Mar 19, 2008 6:26 am     Reply with quote
Nice. I will test it and append this thread about it. But it is not today priority, so il will be in some time.
Thanks for the tip.
Matro.
