richi-d
Always my great problem: how to create the project |
Posted: Wed Mar 12, 2008 6:58 am |
Can anyone tell me how I create a optimal project structure?
Where must be the Header filer and the Subroutines in MPLAB
Where do I have to declare variables
Where is the right place for including the files?
What the right form of the *.h file....
Here is my solution- it doesn´t work:
The error is about 100 times:
*** Error 28 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 153(36,37): Expecting an identifier
*** Error 43 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 154(1,2): Expecting a declaration
MAIN.C:
#include <18F4620.h>
#device adc=10
#include <string.h>
#include "Display_Steuerung.h"
#FUSES HS,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOLVP,NOCPD,NOWRT,DEBUG
#use delay(clock=8000000)
#use STANDARD_IO (A)
#use STANDARD_IO (B)
#use STANDARD_IO (C)
#use STANDARD_IO (D)
#use STANDARD_IO (E)
#define NOP #asm NOP #endasm;
#define LE_MUX_1 PIN_C0
#define LE_MUX_2 PIN_C1
#define LE_MUX_3 PIN_C2
#define LE_MUX_4 PIN_D7
#define CLK PIN_C3
#define DATA PIN_C5
#define LE_DATA_0 PIN_D0
#define LE_DATA_1 PIN_D1
#define LE_DATA_2 PIN_D2
#define LE_DATA_3 PIN_D3
#define AUX_LO_UL PIN_D4
#define AUX_LO_DL PIN_D5
#define PWR_DOWN PIN_D6
#define R_S PIN_E0
#define R_W PIN_E1
#define ENABLE PIN_E2
#define OUTPUT_4 PIN_A4
#define OUTPUT_5 PIN_A5
#define OUTPUT_6 PIN_A7
#define OUTPUT_7 PIN_A6
#define GEBER_1_A PIN_B0
#define GEBER_1_B PIN_B4
#define GEBER_2_A PIN_B1
#define GEBER_2_B PIN_B5
#define ENTER_1 PIN_B2
#define ENTER_2 PIN_B3
int ADRESSE;
int DATA;
int x_POS;
int y_POS;
int THOUS;
int HUNS;
int TENS;
int UNITS;
int DISPLAY_ZAHLER;
short SCHALTZUSTAND_1;
int lenght;
short STATUS_1_A;
short STATUS_1_B;
short STATUS_1_A_ALT;
short STATUS_2_A;
short STATUS_2_B;
short STATUS_2_A_ALT;
short BESTATIGT;
short ENTER_RAD_1_BIT;
short VERSTELLT;
short SPEICHERN;
short CONN_MERKER;
int TYP;
int PART;
long RAD_1;
long RAD_2;
long i;
long x;
long WERT;
#include "Display_Steuerung.c"
Display_Init();
for (;;)
Write_Display_Data ( 0, 1, 'R' );
}// for()
} //main() |
Display_Steuerung.c :
Code: | void Display_Init (void)
output_low(ENABLE);
delay_ms(50);
output_bit( PIN_C0, 1); //Function Set
output_bit( PIN_C1, 1);
output_bit( PIN_C2, 0);
output_bit( PIN_C3, 0);
output_low(R_S);
output_low(R_W);
output_high(ENABLE);
delay_us(5);
output_low(ENABLE);
delay_ms(1);
output_low(R_S);
output_low(R_W);
delay_us(5);
output_low(ENABLE);
delay_ms(1);
output_low(R_S);
output_low(R_W);
delay_us(5);
output_low(ENABLE);
delay_ms(1);
output_bit( PIN_C0, 0); //Function Set 4 BIT
output_low(R_S);
output_low(R_W);
delay_us(5);
output_low(ENABLE);
delay_ms(1);
delay_ms(1);
output_low(R_S);
output_low(R_W);
delay_us(5);
output_low(ENABLE);
output_bit( PIN_C1, 0);
output_bit( PIN_C2, 0); //Display OFF
output_bit( PIN_C3, 1); //2 Lines
delay_us(5);
output_low(ENABLE);
delay_ms(1);
output_bit( PIN_C0, 0); //Display ON/OFF Control
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C1, 0); //Blink ON/OFF
output_bit( PIN_C2, 0); //Cursor ON/OFF
output_bit( PIN_C3, 1); // Display ON/OFF
delay_us(10);
output_low(ENABLE);
delay_ms(1);
output_bit( PIN_C0, 0); //Display Clear
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
delay_us(10);
output_low(ENABLE);
delay_ms(2);
output_bit( PIN_C0, 0); //Entry Mode Set
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C0, 0); //Entire Shift off/on
output_bit( PIN_C1, 1); //Decrement Mode/Increment Mode
delay_us(10);
output_low(ENABLE);
delay_ms(1);
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C2, 1);
delay_us(10);
output_low(ENABLE);
delay_ms(1);
void Write_CG_Data ( ADRESSE, DATA )
delay_ms(1);
output_bit( PIN_C1, BIT_TEST(ADRESSE, 5));
output_bit( PIN_C0, BIT_TEST(ADRESSE, 4));
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C0, BIT_TEST(ADRESSE, 0));
output_bit( PIN_C1, BIT_TEST(ADRESSE, 1));
output_bit( PIN_C2, BIT_TEST(ADRESSE, 2));
output_bit( PIN_C3, BIT_TEST(ADRESSE, 3));
delay_us(10);
output_low(ENABLE);
delay_ms(1);
output_bit( PIN_C0, BIT_TEST(DATA, 4));
output_bit( PIN_C1, BIT_TEST(DATA, 5));
output_bit( PIN_C2, BIT_TEST(DATA, 6));
output_bit( PIN_C3, BIT_TEST(DATA, 7));
output_high(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C0, BIT_TEST(DATA, 0));
output_bit( PIN_C1, BIT_TEST(DATA, 1));
output_bit( PIN_C2, BIT_TEST(DATA, 2));
output_bit( PIN_C3, BIT_TEST(DATA, 3));
delay_us(10);
output_low(ENABLE);
void Write_Display_Data ( x_POS, y_POS, DATA )
delay_ms(1);
if (y_POS == 1)
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C0, BIT_TEST(x_POS, 0));
output_bit( PIN_C1, BIT_TEST(x_POS, 1));
output_bit( PIN_C2, BIT_TEST(x_POS, 2));
output_bit( PIN_C3, BIT_TEST(x_POS, 3));
delay_us(10);
output_low(ENABLE);
if (y_POS == 2)
output_low(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
delay_us(10);
output_low(ENABLE);
delay_ms(1);
output_high(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
delay_us(10);
output_low(ENABLE);
Display_Steuerung.h : Code: |
void Display_Init ( void );
void Write_CG_Data ( int,int );
void Write_Display_Data ( int,int,int );
I added the "main.c" to Source Files
I added the "Display_Steuerung.h" to Header Files
I added the "Display_Steuerung.c" to Other Files
Whats wrong- what does the optimal solution look like? |
Posted: Wed Mar 12, 2008 10:39 am |
Don't put the #include statements all over your program. Put them
near the top, as shown below. Also put the preprocessor statements
before the #include statements. Notice the order of the statements
shown below:
1. The .H file for the PIC.
2. Any #device statements.
3. The #fuses statement.
4. The #use delay statement.
5. Any other #use statements.
6. Other #include statements.
#device adc=10
#include <string.h>
#include "Display_Steuerung.c" |
richi-d
Posted: Thu Mar 13, 2008 1:03 am |
Thanks PCM.... o.k. this was the first step, now I get this error messages:
*** Error 12 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 3(12,18): Undefined identifier ENABLE
*** Error 12 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 10(12,15): Undefined identifier R_S
*** Error 12 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 11(12,15): Undefined identifier R_W
*** Error 12 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 12(13,19): Undefined identifier ENABLE
*** Error 12 "S:\Abteilung\AnaSys\DICE\Software\Extension_Bedienboard\Display_Steuerung.c" Line 14(12,18): Undefined identifier ENABLE
[img]C:\Clipboard_01.jpg[/img]
How must the *.h look like? Where do I declare my variables? |
richi-d
Posted: Thu Mar 13, 2008 8:54 am |
Is it possible to get for example a model project ( in MPLAB) where I can see how everything should be done?
Or is it possible that someone sends me a zipped model project (e-mail)
- without code... |
Posted: Thu Mar 13, 2008 6:19 pm |
Undefined identifier R_W |
I didn't realize that you have all these global variables that are used
in your other modules. To get rid of the error messages, you need to
move the two #include files so they are below all the #define statements
and the global variables.
Put them in the location shown in bold below:
#define CLK PIN_C3
#define DATA PIN_C5
#define R_S PIN_E0
#define R_W PIN_E1
int ADRESSE;
int DATA;
int x_POS;
int y_POS;
int THOUS;
int HUNS;
int TENS;
int UNITS;
int DISPLAY_ZAHLER;
int lenght;
short STATUS_1_A;
short STATUS_1_B;
short STATUS_2_A;
short STATUS_2_B;
short BESTATIGT;
short VERSTELLT;
short SPEICHERN;
short CONN_MERKER;
int TYP;
int PART;
long RAD_1;
long RAD_2;
long i;
long x;
long WERT;
Then you have another problem. You have both a variable and
constant with the same name, DATA. This will not work. It causes
tons of error messages:
Quote: |
#define DATA PIN_C5
int DATA; |
For example, you have all this code that tests 'DATA', but the bit_test()
function will not work if 'DATA' is PIN_C5. It must be a variable.
output_high(R_S);
output_low(R_W);
delay_us(10);
output_low(ENABLE);
output_bit( PIN_C3, BIT_TEST(DATA, 3)); |
You need to fix this problem in the Write_CG_Data() and the
Write_Display_Data() functions. |
