Setup_timer_2 pwm for low frequencies
siddahuja
PostPosted: Sun Mar 09, 2008 2:21 pm     Reply with quote
Hi
Could anyone help me find the values for setting the timer 2 for PIC16F877A so that i can generate the pwm with the following characteristics:
Period: 15.95ms
Frequency: 62.7Hz
Duty Cycle: 10.7%
I am using a clock of 20MHz
Thanks in advance!
sid
PostPosted: Sun Mar 09, 2008 2:41 pm     Reply with quote
This post tells you how to calculate the lowest PWM frequency
that you can get with a 20 MHz oscillator:
http://www.ccsinfo.com/forum/viewtopic.php?t=31625
John P
PostPosted: Sun Mar 09, 2008 6:19 pm     Reply with quote
Maybe it would be better just to generate two time intervals in turn, using time interrupts. First 10.7% of 15.95ms, then 89.3%, and repeat.
Of course, it depends on what else the processor has to do. If you have other things happening which absolutely must generate interrupts, this method won't work. But often there can be alternative approaches which rely on polling rather than interrupts.
