i am making a simple program for PIC 16F877 that can read characters serially (RS-232) from computer. then convert that character to integer so that i can make arithmetic modification (e.g multiply it with 5) and then echo or send it back to computer.
I am having difficulty in converting character to integer (i dont know the built in function). I am new to CCS. Please help me..........
Guest_7068 Guest
Posted: Thu Mar 06, 2008 10:58 pm
Use example Ex_Sisr.c to read characters serially into a buffer and then convert the string into a number using one of the following functions.
#include <stdlib.h>
ivalue = atoi(string) // Returns 8 bit int >> Max String Length = 3
lvalue = atol(string) // Returns 16 bit value >> Max String Length = 5
i32value = atoi32(string) // Returns 32 bit value >> Max String Length = 9
SherpaDoug
Posted: Fri Mar 07, 2008 9:23 am
If the character contains a binary number, just cast the byte from one type to the other. Casting is a standard C term that any C book will cover. _________________ The search for better is endless. Instead simply find very good and get the job done.
