PIC24 PORTB issue.
0xDEADBEEF
PIC24 PORTB issue.
PostPosted: Tue Mar 04, 2008 11:01 am     Reply with quote
Sample code:
fprintf(COMCON, "\rA:%2x\tB:%2x\tC:%2x\tD:%2x\tE:%2x\tFB:%2x\tG:%2x\t", input_A(), input_B(), input_C(), input_D(), input_E(), input_F(), input_G());
1. The input function only returns an 8-bit number (yes, even if I change the printf formatting to %4x) instead of the full 16-bit value... i can work around that though.
2. All the ports are working except PORTB (well I haven't actually checked PORTC, but I'm not using it so I don't care).
No matter what, PORTB always reads as all zeroes.
Chip is a PIC24HJ256GP610 compilier is version 4.064
Any ideas?
0xDEADBEEF
PostPosted: Tue Mar 04, 2008 11:52 am     Reply with quote
UPDATE:
PortB works when I'm running in DEBUG mode through the MPLab ICD2 programmer.
So, apparently this is a compilier issue of some sort. The question is... how do i fix it?
MPlab version is 8.00
Guest_7068
PostPosted: Thu Mar 06, 2008 7:19 pm     Reply with quote
Try using the printf with %LX parameter.
Use the following to shut down the A/D module which is multiplexed on port B.
SETUP_ADC_PORTS(NO_ANALOGS);
