set port for 16f873
arys
set port for 16f873
PostPosted: Wed Mar 05, 2008 11:17 pm     Reply with quote
hi.
I want to set port b as output port.
here are the code. but it doesnt work. does anybody know? it only work if output_high(PIN_Bx). I do not understand?
#byte PORTB=0x06
#byte PORTC=0x07
{   if (INPUT(PIN_C4))
      output_b(0b00000001);
drh
PostPosted: Thu Mar 06, 2008 9:14 am     Reply with quote
At power up, all ports are inputs. You need to change the portb DIRECTION to outputs. See the SET_TRIS_B() command.
David
PostPosted: Thu Mar 06, 2008 9:59 am     Reply with quote
Not true.
The default mode fo the CCS compiler, is 'standard_io' mode. In this mode, the compiler wll _automatically_ insert TRIS commands for you. It works well, and except for the overhead on speed, is perfectly reliable.
The most likely problem is something else 'not shown' in the code.
Post a runnable 'demo' program, showing the fuses, what processor is involved etc. etc.. It should be the bare minimum to show the problem (only really needs the processor selection, clock setup, fuses, and the terminations of the loops).
There is nothing wrong with what is shown, except that it is incomplete.
arys
PostPosted: Thu Mar 06, 2008 6:22 pm     Reply with quote
drh ; I did set_tris_b(0x00); but the output box said error. s'thing involved with declaration. Still dont know. very simple codes.
Ttelmah; here are the codes.
#define (_PCM_)
#include <16F873.h>
#use delay(clock = 4000000)
//#use rs232(baud=2400,xmit=pin_c6, rcv=pin_c7, bits=8, ERRORS)
#byte PORTB=0x06
#byte PORTC=0x07
int8 d;
   if (INPUT(PIN_C5))
   output_b(0b00000010);
arys
PostPosted: Thu Mar 06, 2008 6:25 pm     Reply with quote
forgot to tell you. when i use
--> #include <16F877A.h>
no error in output box
drh
PostPosted: Fri Mar 07, 2008 9:07 am     Reply with quote
Not true.
I was talking about what the PIC does at power up. Whether or not the compiler sets the direction for you, it still needs to be set.
David
