problem with RS232 in 12F675
karthickiw
PostPosted: Wed Mar 05, 2008 11:34 am     Reply with quote
hello..
i try to write the program to send the Hex command through PIC12F675, but i dont receive the any command from PIC...
my complier version is IDE - 3.41
PCB - 3.185
PCM -3.185
PCH - 3.185
#include <12F675.h>
#device adc=8
#fuses NOWDT,INTRC_IO, CPD, PROTECT, NOMCLR, PUT, BROWNOUT
#byte OSCCAL=0x90
#define GP0 PIN_A0
#define GP1 PIN_A1
#define GP2 PIN_A2
#define GP3 PIN_A3
#define GP4 PIN_A4
#define GP5 PIN_A5
#use rs232(baud=9600,parity=N,xmit=PIN_A4,rcv=PIN_A5,bits=9)
#byte ADCON0 = 0x1F
#byte ANSEL = 0x9F
#byte CMCON = 0x19
#rom 0x3ff = {0x3470} // input the calibration code
ADCON0 = 0; // ADC off
ANSEL = 0; // GPIO pins 0,1,2 and 4 set to all digital
CMCON = 7; // Comparators off
set_tris_a(0b100000);
putc(0X7E);
putc(0X07);
putc(0XA0);
putc(0X30);
putc(0X30);
putc(0X30);
putc(0X30);
putc(0X30);
putc(0X7E);
while(1) {
please check the code and give solution...
PostPosted: Wed Mar 05, 2008 12:21 pm     Reply with quote
Why are you using 9 bits ? Standard RS-232 is 8 bits. You don't need
to specify 8 bits in the #use rs232() statement. It's the default value.
Are you using a MAX232 chip ?
See these two threads for more help.
http://www.ccsinfo.com/forum/viewtopic.php?t=32751
http://www.ccsinfo.com/forum/viewtopic.php?t=28067
PostPosted: Wed Mar 05, 2008 3:52 pm     Reply with quote
no, I am using 8 bit, it goes through MAX485,
but the problem arises only with a 20MHz crystal,
it works perfectly with a 10MHz crystal.
So the only logical conclusion is the baud rate generator.
The core is: how to set the baud rate generator manually?
Why it doesn't work, and why the IDE shows 0 for the register
involved and manually set?
PostPosted: Wed Mar 05, 2008 4:04 pm     Reply with quote
There is no baud rate generator in a 12F675. It doesn't have a UART.
It's all done with software polling loops and delays, in the CCS library code.
PostPosted: Wed Mar 05, 2008 4:57 pm     Reply with quote
And (of course), _requires_ that you set the #use delay, to match the frequency the chip is actually running. You talk about using 10MHz, and 20MHz, but the code shown, is for 4Mhz. Remember also the HS fuse. I have seen chips run at 10MHz, with XT selected, but then fail when trying to go faster. What voltage is the power supply?. 20Mhz, requires at least 4.5v.
