I2C + use fast_IO + set_tris_c()
angel
PostPosted: Tue Mar 04, 2008 8:20 am     Reply with quote
Hello
I am going to develop a I2C communication and I was wondering if I can use : use fast_IO and set_tris_c
Using the set_tris_c() command, I can decide which pin is input and output. But what happen with a I2C communication?
PostPosted: Tue Mar 04, 2008 12:37 pm     Reply with quote
The compiler inserts code to set the SDA and SCL pins to be inputs,
as required by the PIC data sheet. Don't change the TRIS on the
SDA and SCL pins.
angel
so...
PostPosted: Thu Mar 06, 2008 8:52 am     Reply with quote
so using RC2 and RC3 for a software I2C communication, the code:
#use fast_io(C)
#define I2C_SDA PIN_C2
#define I2C_SCL PIN_C3
#use I2C (master, sda=I2C_SDA , scl=I2C_SCL)
set_tris_c(0b00001100);
is it correct?
