Problems with the dsPICDEM-Board
JaKo
PostPosted: Fri Feb 29, 2008 5:38 am     Reply with quote
Hey guys
I bought the dsPICDEM-Board and now I program the SPI with
#use spi(FORCE_HW, BITS=16, STREAM=SPI_STREAM)
because I need the SPI for the LCD-Display. And the problem is that i get a clock but my data won´t get send. And I also programmed the LED. If i use
the stop lighting, and if i use
setup_spi
, the LEDs lights but there is no clock and data for the SPI.
Can somebody help me please?
JaKO
PostPosted: Fri Feb 29, 2008 4:11 pm     Reply with quote
There are a large number of dsPICDEM boards. Which one do you have ?
See this link:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2519&param=en025319&page=wwwdsPICDSCDemo
JaKo
dsPICDEM BOard
PostPosted: Tue Mar 04, 2008 6:36 am     Reply with quote
dsPICDEM2 DM300018
JaKo
JaKo
Source code
PostPosted: Tue Mar 04, 2008 7:01 am     Reply with quote
That´s my source code:
#include<30F4011.h>
#fuses HS,NOWDT,NOPROTECT
#use rs232(baud=9600, UART1)
#define LCDLINE1CMD 0x80;
unsigned char DisplayData[] = "Das dsPICDEM2 ";
int8 x;
// char c;
// c="A";
delay_ms(250);
output_high(PIN_B0);
output_low(PIN_B1);
delay_ms(250);
output_high(PIN_B1);
output_low(PIN_B0);
SETUP_SPI(SPI_MASTER|SPI_H_TO_L|SPI_CLK_DIV_64);
SPI_WRITE(DisplayData);
x=SPI_READ(0);
PostPosted: Tue Mar 04, 2008 12:35 pm     Reply with quote
Here's the page for that board.
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=1406&dDocName=en023561
The User's Guide explains how to write a driver for the LCD controller
in this section. But, they don't tell you what SPI mode is required.
Here is the section in the manual that tells how to program the LCD.
B.3 LCD SOFTWARE SPECIFICATION
The page above also has a download called "Software Files". It contains
sample C source code for the LCD driver. The filename is SPI_for_LCD.c.
It contains these functions:
SPI_Init(void)
WriteSPI_to_LCD(void)
It mostly consists of low-level code that writes directly to dsPIC registers.
You could translate it to CCS.
I don't have the PCD compiler, and I don't have time to translate these
routines for you now. I can't really help much more.
