Timer1 Crystal question
Imanjl
View user's profile Send private message Send e-mail Yahoo Messenger
PostPosted: Mon Mar 03, 2008 1:34 pm     Reply with quote
Is it possible to run the Timer1 OSC with 1Mhz external crystal ? I see 18F reference and it suggested value in 32-200Khz range .
If yes what Capacitor value should I use for 1Mhz?
PIC=18f452 ,Freq=40Mhz.
Thx .
PostPosted: Mon Mar 03, 2008 1:43 pm     Reply with quote
From the 18F452 data sheet:
11.2 Timer1 Oscillator
The oscillator is a low power oscillator rated up to 200 kHz.
Imanjl
PostPosted: Mon Mar 03, 2008 3:35 pm     Reply with quote
if I set the timer to operate with internal oscillator it can reach to 10mhz freq when PIC run at 40Mhz .
I think an external clock with 1Mhz Freq can solve the problem ,but I dont have access to external clock source in my board .
Is it possible to connect the PWM output of PIC to timer1 clock input ?
I want to drive the timer with PWM module .
PostPosted: Mon Mar 03, 2008 3:48 pm     Reply with quote
Use a wire and connect the two pins.
Imanjl
PostPosted: Mon Mar 03, 2008 4:01 pm     Reply with quote
Thanks PCM programmer It was done with a piece of wire .
