How do i change resolution bit on DS1631.c driver?
E_KARVELAs
PostPosted: Sat Mar 01, 2008 1:55 pm     Reply with quote
hi
i need to change the resolution bit on the ds1631.c driver
from 12 bit to 10bit
as i found on datasheet i need to
CHANGE and write to the CONFIGURATION REGISTER the values of
R0=1
R1=0
Driver
void init_temp() {
   output_high(DAL_SDA);
   output_high(DAL_SCL);
   i2c_start();
   i2c_write(0x90);
   i2c_write(0x51);
   i2c_stop();
   temp_config(0xc); //  <------- i tryed to change this one from (0xc) to
}      //   R0=1,R1=0   0bxxxx0100=(0x4) but no results
the driver for me works fine but i need to change the resolution from 12bit to 10bit.
maybe someone has already done it.
---- GREECE ----
