I want to insert the degree symbol into the GLCD 128X64
E_KARVELAs
PostPosted: Fri Feb 29, 2008 6:03 pm     Reply with quote
HI i want to show the degree symbol into to the GLCD how can this be done:???
                                        //example code
char   string[9];
float TempVal;                         //store the value of temp
sprintf(string,"%3.1foC",TempVal)      //This code will show 24.4oC
                                       //I need to show  "24.4°C"
                                       //instead of "24.4oC"
---- GREECE ----
JulsPower
PostPosted: Fri Feb 29, 2008 8:54 pm     Reply with quote
draw it
I dont know with the glcd but with the hd44780 you can write into the CG ram
check the manual you can probably do the same
andredurao
PostPosted: Sat Mar 01, 2008 5:56 am     Reply with quote
You'll have to draw it..
increase one line in const BYTE TEXT2
with the followin values....
0b00000000,
0b00011100,
0b00100010,
0b00100010,
0b00011100
and print this char (#127, or you may change some symbol
that you're not using (like '^' ...just a example)
E_KARVELAs
PostPosted: Sat Mar 01, 2008 8:22 am     Reply with quote
0b00000000,
0b00011100,
0b00100010,
0b00100010,
0b00011100
hi
i changed the driver code for "^" to show the degree symbol works just file. Laughing thanks
---- GREECE ----
