Counter output to LCD
marken1
PostPosted: Thu Feb 28, 2008 2:13 pm     Reply with quote
Hi there,
I am working on my project and I am having problems with stopping a binary counter to a certain value.
I have two buttons connected to the inputs of the PIC. The count up button increments the counter by 1 and then display to the lcd, and the counter down button decrements the counter by 1 and display to the lcd.
I am counting in 10 bit and I would like to write a function that if I increment the counter to the maximum value 1023 then the count up button to stop working.
Then I use the countdown button to decrement minimum value 0 and stop working.
At the moment my function rolls over from 1023 – 0 an so on.
There is my code so far:
float iset;
int icount;
//Countup
if(!input(PIN_C2) )
    //Increment COUNT
    //Calculation:
    iCOUNT = iCOUNT + 1;
    iset = (float)(icount * 5)/25.0;
    lcd_gotoxy(7,2);
    printf(lcd_putc, "\iset:%3.2f", iset);
//Countdown
if( !input(PIN_C7) )
    iCOUNT =  iCOUNT - 1 ;
    lcd_gotoxy(7,2);
Any pointers would be really appreciated.
PostPosted: Thu Feb 28, 2008 3:57 pm     Reply with quote
float iset;
int16 icount; //Note _must_ be int16, since you want more than 8bits...
//Countup
if(!input(PIN_C2) )
    if (icount<1023) iCOUNT = iCOUNT + 1;
    lcd_gotoxy(7,2);
//Countdown
    if (icount>0) iCOUNT =  iCOUNT - 1 ;
    lcd_gotoxy(7,2);
It should be fairly easy to work out the effect of the changes shown.
marken1
Problem solved
PostPosted: Wed Mar 05, 2008 3:19 am     Reply with quote
Many thanks. That's just what I was after.
