Franck26
18f4455 Clock and connection review??? |
Posted: Thu Feb 28, 2008 8:52 am |
Hi everybody,
I have a problem with a 18F4455.
I'm working in debugging, my program doesn't contain anything, just the fuses declaration:
Code: | #include <18F4455.h>
#device ICD=TRUE
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV21 //Brownout reset at 2.1V
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOPBADEN //PORTB pins are configured as digital I/O on RESET
#FUSES NOLPT1OSC //Timer1 configured for higher power operation
#FUSES PLL12 //Divide By 12(48MHz oscillator input)
#FUSES CPUDIV4 //System Clock by 4
#FUSES NOUSBDIV //USB clock source comes from primary oscillator
#FUSES NOVREGEN //USB voltage regulator disabled
#FUSES ICPRT //ICPRT enabled
#use delay(clock=20000000) |
The program is loading into the target without problem, and at the windows "Clock and Connection Review" appears.
I can read: "Check the target oscillator and MCLR. Make sure the target clock match the clock fuse and that the target is oscillating..."
I have a 20 MHz quartz with two 15pF capatitors connected to the pic, and it's oscillating correctly. i have 5V on MCLR pin.
I think my fuses configuration are good...
Do you have any idea about this problem?
Thanks,
Franck. |
Posted: Thu Feb 28, 2008 9:08 am |
Some comments, then the answer...
Do you actually have an external _oscillator_, or just a crystal?. You are using the HS fuse, which suggests the latter.
Why on earth use such a high speed oscillator?. The whole 'point' of the oscillator design, is to reduce power, and EMI, by avoiding the need for such a fast external signal. Though the chip is specified to support this frequency of oscillator, it _only_ does so, if the supply is good.
I'd add the PUT fuse. At such a frequency, the ocillators have a habit of starting incorrectly, and then recovering latter...
Your oscillator setup, is illegal for the frequency input. Look at the data sheet. What is the maximum oscillator frequency, using HS, as opposed to HSPLL?....
Your clock frequency, will _not_ be 20MHz.
Your fuses specify that the incoming signal, is divided by 12, to give 4Mhz, then multiplied by 24 to give 96MHz. This is then divided b 2 to give 48MHz for the USB. Your CPU, is fed _directly_ from the incoming clock, fed into the CPUDIV divider. As such, it'll be 48/4MHz. 12MHz, not 20MHz...
However the big problem is your lack of code.
CCS, by default, fills the unused memory with 'sleep' instructions, which inherently stop the clock. So since you have no code, the ICD, is seeing this happening.
Franck26
Posted: Thu Feb 28, 2008 10:35 am |
Hi Ttelmah,
Thanks for your reply.
It's right, I'm using a crystal.
I choose a 20Mhz because I wasn't sure which crystal frequency I need for the USB. So I used the same than the PIC-USB-STK board from Olimex...
About the PLL fuse I thought they wouldn't be use if I'm not setting the HSPLL fuse.
The problem was not in the code, when I said that I don't have any code, I wanted to say no code in the the main loop: while(true){}.
However, I put the PUT fuse and remove the PLL prescaler like you said and it's working.
Just for info, now the fuse setting is:
#device ICD=TRUE
#device adc=8
#FUSES PUT //Power Up Timer
#FUSES NOFCMEN //Fail-safe clock monitor disabled
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES PLL1 //No PLL PreScaler
#FUSES CPUDIV1 //No System Clock Postscaler
#FUSES NOICPRT //ICPRT disabled
I have to check properly all the other fuse, but at least I'm in good shape.
Thanks a lot for your help.
Franck. |
Posted: Thu Feb 28, 2008 3:52 pm |
If you actually have a 20MHz crystal, and you want the CPU to run at 20MHz, then you need to select CPUDIV1 (as you have now), and PLL5 (to generate the useable USB clock), with the USBDIV fuse selected. This will give the 20Mhz for the CPU, and the required 96Mhz for the USB from this crystal.
A search, should find a fairly longish description I published here some time ago, about how to configure the oscillator on these chips.
Franck26
Posted: Fri Feb 29, 2008 11:46 am |
Thanks a lot.
Franck. |
