peter-storm
| SPI freezes PIC16f690 |
Posted: Tue Feb 26, 2008 6:33 pm |
Hi all,
If I implement my code using spi_write() the program works. If I use spi_xfer instead, it hangs at the first instance of this command and I'm not sure why. The help doesn't really explain the difference between spi_write() and spi_xfer(), but it appears that spi_xfer() uses much less memory.
Here is a segment of my code, any help is appreciated.
#fuses HS, NOWDT, NOPROTECT, BROWNOUT
#use delay(clock=8000000)
#use rs232(baud=19200,parity=N,xmit=PIN_B7,rcv=PIN_B5,bits=8,STREAM=ETRX)
#use spi(FORCE_HW,SPI1,MASTER, BITS=8, LSB_FIRST,ENABLE=PIN_C6)
#include <string.h>
#include <vl1001.c>
#include <ascii-bitmapping.c>
here is the function where it crashes:
void upd_lcd()
char time1[18];
char time2[18];
char activity1[18];
char activity2[18];
gets(time1);
gets(activity1);
gets(time2);
gets(activity2);
spi_xfer(0xa3); << this is where it stops working
spi_xfer(0x1a);
etc... |
Posted: Tue Feb 26, 2008 7:05 pm |
1. Make it into a complete test program. Only put lines of code in
the program that are needed to show the problem. For example,
if you can demonstrate the problem without all those #include files
and without all the gets() statements, then delete them.
See my post in this thread, where I show some test programs:
http://www.ccsinfo.com/forum/viewtopic.php?t=33372
This is what I mean. If you can strip your code down to a program
as short as that, then I can probably find the problem.
2. Very important: Post your compiler version. |
peter-storm
Posted: Wed Feb 27, 2008 5:01 am |
#include <16f690.h>
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT
set_tris_c (0x00);
setup_adc_ports (NO_ANALOGS | VSS_VDD);
setup_adc (ADC_OFF);
setup_spi (SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_4);
setup_timer_0 (RTCC_INTERNAL | RTCC_DIV_1);
setup_timer_1 (T1_DISABLED);
setup_timer_2 (T2_DISABLED, 0, 1);
setup_comparator (NC_NC_NC_NC);
setup_oscillator (OSC_8MHZ);
printf("AT+SCAST:UPD\r");
delay_ms(2000);
spi_xfer(01010101);
printf("AT+SCAST:BAT\r");
My compiler version is 4.057.
thanks |
Posted: Wed Feb 27, 2008 12:53 pm |
| Quote: | #include <16f690.h>
set_tris_c (0x00);
delay_ms(2000);
spi_xfer(01010101);
CCS has two methods of using SPI. The original method uses
setup_spi() to configure the SPI module, and spi_write(), spi_read(),
etc., to do the SPI transfers.
The new method does the SPI setup with a #use spi() statement,
and it does the transfers with spi_xfer().
You should not mix these two methods. In your code above, you're
using the new method, so you should delete the setup_spi() statement. |
