		| Author | Message |
		| tipoldo
				| wrong dispatcher code |
				|  Posted: Wed Feb 27, 2008 10:21 am |   |
				| Hi, I'm using the CCS PCM C Compiler Version 3.236 on a PIC 16F690. I have to use the  comp2_isr in my code to implement a project. I get crazy because sometimes the program had really strange behaviour. Analyzing and tracing the assembler code, I found that the compiler doesn't restore the W register well on interrupt return. Here is the interrupt dispatcher code that the CCS generates in my code:
 0003:  NOP
 0004:  MOVWF  7F
 0005:  SWAPF  03,W
 0006:  CLRF   03
 0007:  MOVWF  26
 0008:  MOVF   7F,W
 0009:  MOVWF  25
 000A:  MOVF   0A,W
 000B:  MOVWF  2D
 000C:  CLRF   0A
 000D:  SWAPF  25,F
 000E:  MOVF   04,W
 000F:  MOVWF  27
 0010:  MOVF   20,W
 0011:  MOVWF  28
 0012:  MOVF   21,W
 0013:  MOVWF  29
 0014:  MOVF   22,W
 0015:  MOVWF  2A
 0016:  MOVF   23,W
 0017:  MOVWF  2B
 0018:  MOVF   24,W
 0019:  MOVWF  2C
 001A:  BCF    03.7
 001B:  BCF    03.5
 001C:  MOVLW  8D
 001D:  MOVWF  04
 001E:  BTFSS  00.6
 001F:  GOTO   022
 0020:  BTFSC  0D.6
 0021:  GOTO   035
 0022:  MOVF   27,W
 0023:  MOVWF  04
 0024:  MOVF   28,W
 0025:  MOVWF  20
 0026:  MOVF   29,W
 0027:  MOVWF  21
 0028:  MOVF   2A,W
 0029:  MOVWF  22
 002A:  MOVF   2B,W
 002B:  MOVWF  23
 002C:  MOVF   2C,W
 002D:  MOVWF  24
 002E:  MOVF   2D,W
 002F:  MOVWF  0A
 0030:  SWAPF  26,W
 0031:  MOVWF  03
 0032:  SWAPF  7F,F
 0033:  SWAPF  7F,W
 0034:  RETFIE
 Highlighted in red is the code where the compiler save the W register, watching it, it saves the W register in the 0x25 register and swaps it. To do it, the compiler use a temporal register (0x7F). But when the compiler wanted to restore the W register, it is restored with the value of the 0x7F register (highlighted in blue color) instead of the 0x25 register. Unfortunately the compiler uses the temporal 0x7F register into my interrupt function as a register for temporal variable, and therefore the code doesn't restore right the W register when I come back from the interrupt function.
 To continue with my project, as a workaround, I have written the following assembler code at the end of the interrupt function comp2_isr():
 #ASM
 SWAPF 0x25,W
 MOVWF 0x7F
 #ENDASM
 But I don't like it. How can I resolve it?
		| SherpaDoug
				|  Posted: Wed Feb 27, 2008 10:29 am |   |
				| What compiler version are you using, and have you informed CCS about this?  They don't always monitor this BBS. _________________
 The search for better is endless.  Instead simply find very good and get the job done.
		| tipoldo
				|  Posted: Wed Feb 27, 2008 10:39 am |   |
				| I'm using the PCM Version 3.236, and I haven't informed about this to CCS yet. Where should I do that? |  |
		| SherpaDoug
				|  Posted: Wed Feb 27, 2008 12:25 pm |   |
				| At the top of this page near the CCS logo is a link to "Official CCS Support" Then at the right under Quick Links they tell you how to get official support.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
