Problem with Interrupt
PostPosted: Wed Feb 27, 2008 8:59 am     Reply with quote
I have a little problem with interrupt.
I want to set PIN_A5 to low for 4 minutes. Then I want to set PIN_A5 to lhigh for 6 minutes. Unfortunately it doesn't work. I use a PIC 16F818. Below a part of my code:
#define INTS_PER_SECOND 61                   // (8000000/(4*128*256))
#int_rtcc                                    // This function is called every time
void clock_isr() {                           // the RTCC (timer0) overflows (255->0).
                                             // For this program this is apx 61 times
    if(--int_count==0) {                     // per second.
      ++seconds;
      int_count=INTS_PER_SECOND;
   set_timer0(0);
   setup_counters( RTCC_INTERNAL, RTCC_DIV_128 | RTCC_8_BIT);
   enable_interrupts(INT_RTCC);
output_low(PIN_A5);
        if(seconds == 240)
          output_high(PIN_A5);
        if(seconds == 600)
          output_low(PIN_A5);
          seconds = 0;
Thanks!
tipoldo
PostPosted: Wed Feb 27, 2008 9:40 am     Reply with quote
Do you set the watchdog time dissable?
Humberto
PostPosted: Wed Feb 27, 2008 9:50 am     Reply with quote
In this device PIN_A5 is an INPUT pin ONLY.
Use another pin with I/O capability.
Humberto
