floating number via RS232
spom
PostPosted: Tue Feb 26, 2008 7:38 am     Reply with quote
I'm using PIC 18F2480 and I want to receive a floating point number from PC via RS232.
How can I do this?
Thanks!
SherpaDoug
PostPosted: Tue Feb 26, 2008 7:54 am     Reply with quote
Data sent by RS232 is sent either as ASCII characters or binary bytes. For beginners it is probably easier to deal with ASCII. Read each digit, check it for validity, add it to the variable. If another digit comes in multiply the variable by 10 and repeat. If a decimal point comes in start dividing by 10 instead of multiplying. If you might get an exponent character you will have to deal with that too.
Start real simple like 1234, then get more complex like -12.34. eventually you can handle 1.234,5E-3 if need to go that far.
