I can increase the duty cycle and it is good for me.
I would like to do high with value 1.5 in hexadecimal.
is it possible?
Posted: Mon Feb 25, 2008 11:15 am
No. But you could use the delay_us() function instead of delay_ms().
Then you can pass it a parameter (int16) of 1500. A delay of 1500 us
is the same as 1.5 ms.
alex Guest
Posted: Mon Feb 25, 2008 8:29 pm
thanks, PCM programmer.
I will test your sugestion.
And I will post here the result.
