Correct setup internal 32Mhz; OSC_32MHZ
Torello
PostPosted: Sun Feb 24, 2008 9:13 am     Reply with quote
Just to share:
setup_oscillator(OSC_INTRC | OSC_32MHZ);
Will not select the PLL and set the pic into 32Mhz. Why? Because the OSC_INTR sets bit 1 of OSCCON and this selects the internal oscillator block as system clock.
The PLL only works on the internal oscillator block when:
- the primary oscillator is selected as system clock (OSCCON b1/b0=00)
- the fuses are set to INTRC or INTRC_IO
- 4Mhz or 8Mhz is selected from the oscillator block.
Thus correct CCS setup:
- #FUSES INTRC_IO or INTRC (thus making the internal block primary)
- setup_oscillator(OSC_32MHZ);
- setup_oscillator(OSC_32MHZ); -or- setup_oscillator(OSC_8MHZ | OSC_PLL_ON);
Regards,
Edwin
PostPosted: Sun Feb 24, 2008 3:29 pm     Reply with quote
You need to specify what this information applies to.
Example:
1. The compiler. Presumably PCH or PCD ?
2. The compiler version.
3. The PIC.
Remember, we are not mind-readers.
PostPosted: Sat Mar 01, 2008 6:33 am     Reply with quote
Sorry forgotten:
Compiler PCHW version 4.068
Pic18 series, tested on Pic18LF4620
