How to setup internal oscillator in a 16F88
arunb
PostPosted: Fri Feb 22, 2008 7:19 am     Reply with quote
PCM: 3.169
MCU: 16F88
I would like to setup the internal oscillator of the 16F88. I found that the header file for the device did not contain INTRC_IO, and the compiler returned an error.
I searched for previous posts related to this query, and found that most people used INTRC_IO.
I fail to understand how this can be done.
Kindly help.
thanks
arunb
PS:
Here is the extract of the header file
 Fuses: LP,XT,HS,EC_IO,NOWDT,WDT,NOPUT,PUT,MCLR,NOMCLR,BROWNOUT
//////// Fuses: NOBROWNOUT,LVP,NOLVP,CPD,NOCPD,WRT,NOWRT,DEBUG,NODEBUG,CCPB0
//////// Fuses: CCPB3,PROTECT,NOPROTECT
rnielsen
PostPosted: Fri Feb 22, 2008 9:47 am     Reply with quote
INTRC_IO is a valid fuse for the 16F88. It tells the compiler to use the internal oscillator and _not_ output the clock pulses to an output. You need setup_oscillator(OSC_8MHZ) in your main() to finish setting things up. This will configure the PIC to run at 8MHZ but there are several other frequencies that you can set it to.
Ronald
arunb
RE:
PostPosted: Sat Feb 23, 2008 2:19 am     Reply with quote
Thanks a lot, i got it working but only after installing PCM compiler version 3.224, i was previously using 3.169 which did not have the INTRC_IO oscillator setup.
arunb
