Reading DIP switches and Outputting ADC Result
jonnylazer
PostPosted: Thu Feb 21, 2008 3:47 am     Reply with quote
Hi people,
just wondered if any one could help.....my program reads 4 ADC channels on my PIC (16f916) and stores the results in varables X1,X2,Y1 and Y2..
What I want to do is read two dip switches connected to port C (bits 0 and 1) and depending on the value display the relevant ADC result on Port B
i.e. if switches read...
00: then display X1 on port B
01: then display X2 on port B
10: then display Y1 on port B
11: then display Y2 on port B
any ideas would be welcome
thanks
crystal_lattice
Dip Switches
PostPosted: Thu Feb 21, 2008 4:24 am     Reply with quote
if (dip_0==1)
   if (dip_1==1)
      //two dips ON aka binary 3
      //Dip_1=ON Dip_0=Off aka binary 1
   if (dip_1==1)
      //Dip_0=OFF Dip_1=ON aka binary 2
      //no dips ON aka binary 0
Dip_0 LSB, Dip_1 MSB
You could also combine the bits into a int and use a switch(no pun intended) statement, but think this will suffice.
Regards
Wayne_
PostPosted: Thu Feb 21, 2008 5:26 am     Reply with quote
switch(input_c() & 0x03) {
case 0x00: // no dips
  printf("...");
case 0x01: // dip1 only
  printf("...");
case 0x02: // dip2 only
  printf("...");
case 0x03: // both
  printf("...");
jonnylazer
PostPosted: Fri Feb 22, 2008 5:42 am     Reply with quote
HI
I have simplified things because I think the problem is a basic one..
here is some code I have written... what it attempts to do is check what value is on PIN_A0, if its a 1 then output 0xFF to port B and if its a 0 then output 0x00 to port B .
#INCLUDE <16f916.h>
#DEFINE DEVICEOSC 8000000
#fuses HS,NOWDT,PUT,NOPROTECT,BROWNOUT,
#use delay(clock=DEVICEOSC)
#DEFINE IN PIN_A0
void LEDS_ON(void){
output_b(0xFF);}
void LEDS_OFF(void){
output_b(0x00);}
void main(void) {
while(true)
if (input(IN))
LEDS_ON ();
LEDS_OFF ();
can anybody see whats wrong here???
thanks for reading
