putc timeout?
Zer0flag
putc timeout?
PostPosted: Thu Feb 21, 2008 5:19 am     Reply with quote
Hi all!
Reading the forum it looks like putc() is described as a blocking function. Though when my PIC is not connected to a PC my program just continues to work and does not block. So there must be some timeout?
Best regards,
Zer0flag
PostPosted: Thu Feb 21, 2008 6:28 am     Reply with quote
More complex than this.....
A _single_ putc, to the hardware port, will return immediately.
Three putc's to the same port, will wait till the first sends, before returning.
On a 'software' UART, putc will wait till the character is sent, before returning.
Normally, unless you add tests for RTS/CTS, putc itself, will send data, whether the connection is present or not (this is almost certainly why your code does not function differently without the PC).
Getc, _will_ wait till data arrives (and hence block).
Zer0flag
PostPosted: Thu Feb 21, 2008 7:00 am     Reply with quote
Thank you for the fast reply Ttelmah,
I am using the HW UART on a PIC18 and when my program starts it sends an identification string to the RS232:
#use rs232(baud=19200, parity=N, bits=8, stop=1, xmit=PIN_C6, rcv=PIN_C7, ERRORS)
//-------------------- Outputs a char to the rs232, can also send strings
void rs232_putc(char c)
   putc(c);
//------------- Sends the identification string of the device
void rs232_send_ident()
   rs232_putc("MANUFACTURER ");
   rs232_putc(DEV_MODEL);
   rs232_putc(", HW: ");
   rs232_putc(HARDWARE_TYPE);
   rs232_putc(HARDWARE_VERSION);
   rs232_putc(", SW: v");
   rs232_putc(SOFTWARE_VERSION);
   rs232_putc(", Ser#: ");
   printf("%lu", SERNUM);
So there should be more than 3 putc() but the function does not block my program...
Wayne_
PostPosted: Thu Feb 21, 2008 8:05 am     Reply with quote
More importantly How the hell is your program working ?
Passing a string (pointer) to a function which accepts only a char should not compile let alone run.
SherpaDoug
Re: putc timeout?
PostPosted: Thu Feb 21, 2008 8:08 am     Reply with quote
Using just the usual RS232 RX & TX lines the PIC has no way of knowing if anything is connected to the other end of the wire. It won't behave differently if the PC is or is not present.
PostPosted: Thu Feb 21, 2008 8:58 am     Reply with quote
It'll run, because this is a standard 'shortcut' in CCS C, to get round the lack of support for constant pointers. If a function that expects a single character, is called with a constant string, the compiler automatically calls the function multiple times, once for each single character.
To ZeroFlag, read the penultimate line of my reply. Putc, actually _never_ blocks. It'll _delay_ by one or more character times, but unless _you_ add tsting for line status (RTS/CTS), the function wil always just send the data, and not care at all about what is at the other end...
Zer0flag
PostPosted: Thu Feb 21, 2008 10:03 am     Reply with quote
Thank you for the clarification. So I will assume that my character sending does not block and will not slow down my program significantly. This means that there is no need to implement an interrupt triggered send buffer, right?
Best regards,
Zer0flag
Douglas Kennedy
PostPosted: Fri Feb 22, 2008 5:33 pm     Reply with quote
Remember the transmission and reception are asynchronous. Consider the PIC when its transmitting then it cannot guarantee that the sender is ready nor can it always assume that its transmit hardware is finished with the last character. Now most PIC code is written to send chars with out regard to the receivers situation. Most often it is a PC with speed and buffer advantages that make it unlikely it can be overrun. In the PC case the TBE isr may not be necessary or even wanted. Now back to the PIC. Suppose your PIC code at some moment has oodles of chars to send. Then the chars could be written to a buffer and a TBE isr would chew on the buffer sending the data at the baud rate chosen ( as if in background). While the isr chews on the data your PIC is fee to move on and do something else. As long as the average transmission out through put is less than the max baud rate you have effectively burst a chunk of data into a buffer at MIPS speed rather than chugging along at baud speed. I would guess most writing code for a TBE isr have a transmit buffer in mind.
Zer0flag
PostPosted: Mon Feb 25, 2008 10:08 am     Reply with quote
This is a really good explanation Douglas. Thank you very much. BTW, can you think of any *disadvantages* a buffered interrupt driven transmit routine may have?
