How second pic received data from first pic?
sorasit46
PostPosted: Wed Feb 20, 2008 12:14 am     Reply with quote
I want the first pic send data to second pic. How second pic received data from first pic? ( I want source code command.)
Ex.
/****** first pic *****/
#include <12F675.h>
#define dataout pin_a5 // data output
byte table[3]={0x3F,0x06,0x5B}; // {0,1,2}
byte data[3];
data[0]=table[0];
data[1]=table[1];
data[2]=table[2];
.for (i_send=1;i_send<=24;++i_send) output_bit(dataout,shift_left(data,3,0);
on second pic (such as 12F675) . How can received data 0,1,2 from master pic ?
/****** second pic *****/
#include <12F675.h>
#define datain pin_a4 // data input
.what command to get data input from pin_a4?;
regards
SherpaDoug
PostPosted: Wed Feb 20, 2008 8:34 am     Reply with quote
I don't think this:
output_bit(dataout,0x06);
does what you think it does. The function output_bit only outputs BITS. It can not take 0x06 as an argument. Since dataout is a single digital pin it can only have one voltage value at a time.
If you want to send a byte serially on a pin you need to use the #useRS232() directive with putc() and getc(). If you are just talking PIC to PIC over a short distance with a common ground you do not need RS232 hardware drivers, but you need the RS232 functions. Look for the keywords "RS232" and "serial" to get more info than you can imagine.
sorasit46
sorry! reask again
PostPosted: Wed Feb 20, 2008 10:20 am     Reply with quote
Who have example source code?
thanks
