Absolute value with 10bit ADC readings
davefromnj
PostPosted: Tue Feb 19, 2008 1:15 pm     Reply with quote
Hello All,
I would like to take the absolute value of 2 unsigned 10bit adc readings. All I want is to see if the difference between these 2 10bit ADC readings is greater than 10.
I know about underflowing with subtraction, and that apparently you cannot use Abs() with unsigned variables.
IS THERE ANY WAY TO DO THIS IN A LESS CONVOLUTED MANNER?
So to find out if Delta ADC1-ADC2 is > 10. I am going to use the
following code:
unsigned long int adcvalue1;
unsigned long int adcvalue2;
unsigned long int result;
unsigned int holdingvariable_a;
unsigned int holdingvariable_b;
if (adcvalue1 > adcvalue2)
holdingvariable_a = adcvalue1;
holdingvariable_b = adcvalue2;
holdingvariable_a = adcvalue2;
holdingvariable_b = adcvalue1;
result = holdingvariable_a - holdingvariable_b;
if (result > 10)
perform an event.
perform a different event.
Ken Johnson
PostPosted: Tue Feb 19, 2008 2:42 pm     Reply with quote
if ( a > b )
delta = a - b;
else delta = b - a;
Ken
