How set parameter input(pin) command
jjude
PostPosted: Tue Feb 19, 2008 12:49 am     Reply with quote
#define INPUT_A PIN_B0
#define INPUT_B PIN_B1
#define INPUT_C PIN_B2
#define OUTPUT_A PIN_A0
#define DATA_1 0 // or 1
My code is now this, two while-loop.
void program()
output_high(OUTPUT_A);
if(DATA_1 == 0)
while((input(INPUT_A) == 1) && (INPUT_C == 0))
output_low(OUTPUT_A);
while((input(INPUT_B) == 1) && (INPUT_C == 0))
return;
I want write code one while-loop, but how?
void program()
data_x = ??; // How i do this?
if(DATA_1 == 1)
data_x = ???; // How i do this;
while((input(data_x) == 1) && (INPUT_C == 0)) // How i do this?
return;
SORRY BAD ENGLISH.
PostPosted: Tue Feb 19, 2008 12:55 am     Reply with quote
Post your compiler version.
jjude
PostPosted: Tue Feb 19, 2008 1:17 am     Reply with quote
4.066 (PCW)
PostPosted: Tue Feb 19, 2008 1:46 am     Reply with quote
I don't completely understand your problem. Your code has many
strange things in it.
if(DATA_1 == 1)
Because DATA_1 is defined as 0, the code above is the same
thing as this code:
if(0 == 1)
The if() statement will not execute. Is that what you want to happen ?
Then you have this code:
But INPUT_C is defined as PIN_B2, so the code is the same as this:
while((input(INPUT_A) == 1) && (PIN_B2 == 0))
(PIN_B2 == 0) will always be False. So the while() statement will
never execute.
Your code has too many problems. Please fix all the problems
so I can understand it.
