Tiny Bootloader PIC18F8722
Jody
PostPosted: Mon Feb 18, 2008 8:08 am     Reply with quote
I am trying to use the tiny bootloader with a 18F8722....
And to make tinks more complez I have also a RS485 connection...
Receive and Transit is connected like the normal RS232 pins.. ie through a SN75176.... This works... Have connected the RE/DE pin to RE0. And when I use the tiny bootlader with a modificated Tinybootloade.ASM I can get the HEX file into the PIC..... But when it should run after a reset I can't get any contact with it....... anyone a idea?????
include mine ASM file.
Thanks in advance,
Jody
   radix DEC
   LIST      P=PIC18F8722   ; change also: Configure->SelectDevice from Mplab
   xtal EQU 10000000     ; you may want to change: _XT_OSC_1H  _HS_OSC_1H  _HSPLL_OSC_1H
   baud EQU 19200        ; standard TinyBld baud rates: 115200 or 19200
   ; The above 3 lines can be changed and buid a bootloader for the desired frequency (and PIC type)
   ;   Tiny Bootloader      18F series      Size=132words
   ;   claudiu.chiculita@ugal.ro
   ;   http://www.etc.ugal.ro/cchiculita/software/picbootloader.htm
   #include "C:\MentorProjects\Bootloader_RS485\icdpictypes.inc"   ;takes care of: #include "p18fxxx.inc",  max_flash, IdTypePIC
   #include "C:\MentorProjects\Bootloader_RS485\spbrgselect.inc"   ; RoundResult and baud_rate
      #define first_address max_flash-264      ;132 words
;      __CONFIG   _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
;      __CONFIG   _CONFIG2L, _BOR_ON_2L & _BORV_20_2L & _PWRT_ON_2L
;      __CONFIG   _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
;      __CONFIG   _CONFIG4L, _STVR_ON_4L & _LVP_OFF_4L & _DEBUG_OFF_4L
;----------------------------- PROGRAM ---------------------------------
      cblock 0
      crc
      i
      cnt1
      cnt2
      cnt3
      counter_hi
      counter_lo
      flag
      endc
      cblock 10
      buffer:64
      dummy4crc
      sendb   ; Byte to send
      d1      ; For delay routine
      endc
;0000000000000000000000000 RESET 00000000000000000000000000
      ORG     0x0000
      GOTO    IntrareBootloader
;view with TabSize=4
;&&&&&&&&&&&&&&&&&&&&&&&   START     &&&&&&&&&&&&&&&&&&&&&&
;----------------------  Bootloader  ----------------------
;PC_flash:      C1h       U            H         L         x  ...  <64>   ...  crc
;PC_eeprom:     C1h     40h         EEADR    EEDATA    0      crc
;PC_cfg         C1h     U OR 80h      H         L         1      byte   crc
;PIC_response:      type `K`
      ORG first_address      ;space to deposit first 4 instr. of user prog.
      nop
      nop
      nop
      nop
      org first_address+8
IntrareBootloader
        movlw b'11111110' ;RE_DE SN75176 zit op RE0
       movwf TRISE
        movlw b'10111111'
       movwf TRISC
                     ;init serial port
      movlw b'00100100'
     movwf TXSTA
      movlw spbrg_value
      movwf SPBRG
      movlw b'10010000'
      movwf RCSTA
                     ;wait for computer
      rcall Receive
      sublw 0xC1            ;Expect C1h = 'K'
      bnz way_to_exit
      movlw IdTypePIC
      rcall SendW               ;send PIC type
MainLoop
      movlw 'K'
      rcall SendW               ; "-Everything OK, ready and waiting."
mainl
      clrf crc
      rcall Receive         ;Upper
      movwf TBLPTRU
    movwf flag         ;(for EEPROM and CFG cases)
      rcall Receive         ;Hi
      movwf TBLPTRH
    movwf EEADR         ;(for EEPROM case)
      rcall Receive         ;Lo
      movwf TBLPTRL
    movwf EEDATA      ;(for EEPROM case)
      rcall Receive         ;count
      movwf i
      incf i
      lfsr FSR0, (buffer-1)
rcvoct                  ;read 64+1 bytes
    movwf TABLAT      ;prepare for cfg; => store byte before crc
      rcall Receive
      movwf PREINC0
      decfsz i
      bra rcvoct
      tstfsz crc            ;check crc
      bra ziieroare
    btfss flag,6      ;is EEPROM data?
    bra noeeprom
    movlw b'00000100'   ;Setup eeprom
    rcall Write
    bra waitwre
noeeprom
    btfss flag,7      ;is CFG data?
    bra noconfig
    tblwt*            ;write TABLAT(byte before crc) to TBLPTR***
    movlw b'11000100'   ;Setup cfg
    rcall Write
    bra waitwre
noconfig
                     ;write
eraseloop
      movlw   b'10010100'      ; Setup erase
      rcall Write
      TBLRD*-               ; point to adr-1
writebigloop
      movlw 8               ; 8groups
      movwf counter_hi
      lfsr FSR0,buffer
writesloop
      movlw 8               ; 8bytes = 4instr
      movwf counter_lo
writebyte
      movf POSTINC0,w         ; put 1 byte
      movwf TABLAT
      tblwt+*
      decfsz counter_lo
      bra writebyte
      movlw   b'10000100'      ; Setup writes
      rcall Write
      decfsz counter_hi
      bra writesloop
waitwre
      ;btfsc EECON1,WR      ;for eeprom writes (wait to finish write)
      ;bra waitwre         ;no need: round trip time with PC bigger than 4ms
      bcf EECON1,WREN         ;disable writes
      bra MainLoop
ziieroare               ;CRC failed
      movlw 'N'
      rcall SendW
      bra mainl
;******** procedures ******************
; Delay is needed because the SN75176 need time for transitions.
; Only required for the RE_DE line.
Delay50us
      movlw   165*xtal/40000000
      movwf   d1
Delay_0
      decfsz   d1, f
      goto   Delay_0
      return
SendW
    movwf sendb
     bsf PORTE,0        ; RE_DE_485 PORTE pin 0 hoog maken om RS485 te zenden
      btfss PIR1,TXIF
      goto $-2
      rcall Delay50us
      movff sendb,TXREG
      nop
      btfss TXSTA,TRMT
      goto $-2
      bcf PORTE,0             ; RE_DE_485 PORTE pin 0 laag maken om RS485 te ontvangen
      rcall Delay50us
      return
Write
      clrwdt
      movwf EECON1
      movlw 0x55
      movwf EECON2
      movlw 0xAA
      movwf EECON2
      bsf EECON1,WR         ;WRITE
      nop
   ;nop
      return
Receive
    clrwdt
      movlw xtal/2000000+1   ; for 20MHz => 11 => 1second delay
      movwf cnt1
rpt2
      clrf cnt2
rpt3
      clrf cnt3
rptc
    btfss PIR1,RCIF         ;test RX
    bra notrcv
    movf RCREG,w         ;return read data in W
    addwf crc,f            ;compute crc
    return
notrcv
      decfsz cnt3
      bra rptc
      decfsz cnt2
      bra rpt3
      decfsz cnt1
      bra rpt2
      ;timeout:
way_to_exit
      bcf   RCSTA,   SPEN         ; deactivate UART
    movlw b'11111111'
    movwf TRISC
      bra first_address
; After reset
; Do not expect the memory to be zero,
; Do not expect registers to be initialised like in catalog.
            END
D-Kens
PostPosted: Mon Feb 18, 2008 10:21 am     Reply with quote
Hi...
I'm surprised by your post, as it took me less than 2 minutes to have Tiny Bootlader working on a PIC18F4620. What do you mean "I manage to get the HEX file into the PIC" ? When I read your problem, I'm afraid I understand that you use the programm Tiny Bootloader to load the bootloader firmware into your PIC, which can't work, as far as I know.
You didn't need either to post the ASM code from the bootlader : except the 3 first configuration lines, it's all working code and we all have the same. Smile
The process is to load the bootloader firmware into your PIC (I use ICD programmer for that), then at reset your PIC will enter the bootloader mode, which means it'll wait for you to send your own programm using Tiny Bootloader. Check the settings for your serial port (Tiny Bootloader uses 115200 bauds by default, but your firmware in ASM says you use a 19200 bauds connection on the PIC side) : then click on "write flash" to begin programmation... It HAS to work !
Good luck, young padawan.
Christophe.
PostPosted: Mon Feb 18, 2008 11:29 am     Reply with quote
Well working with "just" RS232 I has no problems....
And I wrote a simple LED flash program...
The bootloader I program with the CCS ICD..
And then I program mine hex file with tiny bootloader to the PIC...
So far.. so good...
when I now reset the PIC to progam doesn't run........ that is the LED doesn't flash.....
And: "Good luck, young padawan" what age are you... calling someone else "young"????
Regards,
Jody
Re: Tiny Bootloader PIC18F8722
PostPosted: Mon Feb 18, 2008 8:18 pm     Reply with quote
Jody,
I think I see a couple of possible issues.
First, why would you provide a 50us delay for the enable transition? The 75176bp data sheet I looked at indicated an enable line latency of ~80ns (nano-seconds).
Secondly, in the following code snippet, it appears that you are looping while waiting for the TXIF register to be set. Is this necessary? I mean if you load the TXREG and wait for the TRMT to set, as you are doing, why then do you subsequently need to test the TXIF prior to sending the next byte?
SendW
movwf sendb
btfss PIR1,TXIF
goto $-2
rcall Delay50us
movff sendb,TXREG
nop
btfss TXSTA,TRMT
goto $-2
rcall Delay50us
return
Jody
PostPosted: Tue Feb 19, 2008 3:19 am     Reply with quote
Hello Christophe,
Oke It seems that we found it....
Delay 50uS was just stupid....... I made a mistake.....
And the RE0 pin has a small pulldown resitor on the line..... The SN75176 was not always enabled.... Again I made the mistake.....
Right now it is working like I was expecting it......
Thanks for the help!!!!
Jody
