How to insert int into unsigned long?
pgaastra
PostPosted: Thu Feb 14, 2008 7:44 pm     Reply with quote
Sorry for the simple question but I'm trying to insert a hi byte into an unsigned long without multiplying by 256 or left shifting 8 times.
I had the following code:
byte* BytePointer;
unsigned long RedDifference;
BytePointer = &RedDifference
*BytePointer = 0x01;
BytePoint++;
*BytePointer = 0x02;
but get error "LVALUE required"
I really need to read a tutorial on pointers I suppose.
PostPosted: Thu Feb 14, 2008 9:42 pm     Reply with quote
Use the make16() function. It's built-in to the CCS compiler.
See the test program shown below. It displays the following output.
0201
#include <18F452.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
int16 RedDifference;
RedDifference = make16(0x02, 0x01);
printf("%lx", RedDifference);
See the CCS manual for information on make8(), make16(), and make32().
http://www.ccsinfo.com/downloads/CReferenceManual.pdf
RLScott
Re: How to insert int into unsigned long?
PostPosted: Fri Feb 15, 2008 6:08 am     Reply with quote
If you are doing this for optimization purposes, then you should know that in most cases the CCS compiler will recognize what you are doing when you shift left 8 bits and it will emit code that does just what you are trying to do, that is to move whole bytes to the appropriate place. So go ahead and write:
MyLongInt = (TheHighByte<<8) | (TheLowByte);
and the compiler optimization will do the right thing with it.
Robert Scot
Real-Time Specialties
pgaastra
PostPosted: Sun Feb 17, 2008 1:00 pm     Reply with quote
Thanks Robert,
doing the <<8 certainly does get optimised.
pgaastra
PostPosted: Sun Feb 17, 2008 1:06 pm     Reply with quote
Thanks PCM programmer
I am using an ancient compiler v2.731. I'll have to upgrade some time.
I'll see how I go with Robert Scot's advice that <<8 gets optimised by the compiler.
PostPosted: Sun Feb 17, 2008 3:57 pm     Reply with quote
Here is a make16() macro, as shown in the test program below,
that will work with your version of the compiler:
#include "c:\Picc\Examples\16F877.h"
#define make16(msb, lsb)  ((msb << 8) | lsb)
long result;
result = make16(0x12, 0x34);
Look at the .LST file to see the results:
0000        00219 .... result = make16(0x12, 0x34);
000B 3012   00220 MOVLW  12
000C 00A2   00221 MOVWF  22  // Put 0x12 into MSB of 'result'
000D 3034   00222 MOVLW  34
000E 00A1   00223 MOVWF  21  // Put 0x34 into LSB of 'result'
pgaastra
PostPosted: Sun Feb 17, 2008 4:21 pm     Reply with quote
Thanks once again PCM Programmer.
I see I need to read up on macros too!
