i2C_Stream
robotam
i2C_Stream
PostPosted: Wed Feb 13, 2008 3:36 pm     Reply with quote
Hello
Someone could post a example code of i2c communication using "Stream".
thanks
rnielsen
PostPosted: Thu Feb 14, 2008 9:52 am     Reply with quote
As far as I know, STREAM is only available with the RS232, not the I2C.
Ronald
PostPosted: Thu Feb 14, 2008 11:43 am     Reply with quote
Streams can be specified in the #use i2c() statement in vs. 4 of the
compiler. See the current manual:
http://www.ccsinfo.com/downloads/CReferenceManual.pdf
To answer the question, specify the name of the stream in the #use i2c()
statement. Do this in the same way as a stream is specified in a
#use rs232() statement. Then, in every i2c function, specify the stream
that you're using.
Instead of doing this:
i2c_write (data);
You would do this:
i2c_write (stream, data);
All the rest of the i2c functions must also have a stream parameter
(if you are using streams). Example:
i2c_poll(stream);
data = i2c_read(stream);
data = i2c_read(stream, ack);
i2c_start(stream);
i2c_start(stream, restart);
i2c_stop(stream);
