Problem with 4x4 Keypad Scan (Without Pull-up)
Goto page 1, 2  Next
Guest101
PostPosted: Tue Feb 12, 2008 10:28 pm     Reply with quote
Hi all,
i did some modification to the codes which i found here but i cant seem to get it to work on hardware. I've successfully simulated it using proteus. Can someone help me out with this? Thanks in advance
#include <18F2680.h>
#fuses HS,NOPROTECT,NOLVP,NOWDT
//Keypad connection:
#define row0 PIN_A0
#define row1 PIN_A1
#define row2 PIN_A2
#define row3 PIN_A3
#define col0 PIN_C0
#define col1 PIN_C1
#define col2 PIN_C2
#define col3 PIN_C3
// Keypad layout:
int const KEYS[4][4] =
{{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}};
#define KBD_DEBOUNCE_FACTOR 33
short int ALL_ROWS (void)
if(input (row0) || input (row1) || input (row2) || input (row3))
return (1);
return (0);
char kbd_getc()
static byte kbd_call_count;
static short int kbd_down;
static char last_key;
static byte col;
byte kchar;
byte row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR)
switch (col)
case 0:
output_high(col0);
output_low(col1);
output_low(col2);
output_low(col3);
case 1:
output_low(col0);
output_high(col1);
output_low(col2);
output_low(col3);
case 2:
output_low(col0);
output_low(col1);
output_high(col2);
output_low(col3);
case 3:
output_low(col0);
output_low(col1);
output_low(col2);
output_high(col3);
if(kbd_down)
if(!ALL_ROWS())
kbd_down=false;
kchar=last_key;
last_key='\0';
if(ALL_ROWS())
if(input (row0))
row=0;
else if(input (row1))
row=1;
else if(input (row2))
row=2;
else if(input (row3))
row=3;
last_key =KEYS[row][col];
kbd_down = true;
else {
++col;
if(col==4)
col=0;
kbd_call_count=0;
return(kchar);
char k;
printf("\r\Starting ...");
k=kbd_getc();
if(k!=0)
if(k=='*')
printf("%c", '*');
printf("%c", k);
PostPosted: Tue Feb 12, 2008 10:40 pm     Reply with quote
Add pull-up resistors on the row pins. You can use 10K resistors.
fms
PostPosted: Wed Feb 13, 2008 2:14 am     Reply with quote
This would result changes in the hardware design. There are many design which uses this concept (without pullup). but why it wouldn't work using PIC C?
PostPosted: Wed Feb 13, 2008 6:06 am     Reply with quote
Row scanning like this, should work fine with CCS. I do it on several keyboards OK.
So, there has to be something wrong in the code, or approach...
The code as written, does make it quite hard to follow the sequence being used.
Comments:
You seem to only change the column addressed, when the debounce factor is met. It is reset, whenever the routine exits, so will never go true...
Before testing all rows, you really want to initially set all columns, then this will say if any key is pressed. At present, because of the comment above, _no_ column will be set...
The code failing, is not because of CCS.
fms
PostPosted: Wed Feb 13, 2008 7:11 am     Reply with quote
Dear Ttelmah,
Thanks for the explanation. mind if u share us your codes? This would help me alot.
fms
4x4 Keypad Scan (Without Pull-up) (SOLVED)
PostPosted: Thu Feb 14, 2008 12:12 pm     Reply with quote
Dear ALL,
I've retested and reconfirmed that my code is just fine and working perfectly. The problem is with the floating of my row input pins. Pull them low and everything works beautifully. Hope this will help many out there.
//Code Edited by AdrianKhoo from CCS forum (www.ccsinfo.com).
#define ROW0 PIN_A0
#define ROW1 PIN_A1
#define ROW2 PIN_A2
#define ROW3 PIN_A3
#define COL0 PIN_C0
#define COL1 PIN_C1
#define COL2 PIN_C2
#define COL3 PIN_C3
// Keypad layout:
{{'1','2','3','A'},
 {'4','5','6','B'},
 {'7','8','9','C'},
 {'*','0','#','D'}};
short int ROW_HIGH()
if(input (ROW0) || input (ROW1) || input (ROW2) || input (ROW3))
   return (1);
   return (0);
char kbd_getc()
static byte col;
byte kchar;
byte row;
kchar='\0';
   switch (col)
         case 0:
         output_high(col0);
         output_low(col1);
         output_low(col2);
         output_low(col3);
         case 1:
         output_low(col0);
         output_high(col1);
         output_low(col2);
         output_low(col3);
         case 2:
         output_low(col0);
         output_low(col1);
         output_high(col2);
         output_low(col3);
         case 3:
         output_low(col0);
         output_low(col1);
         output_low(col2);
         output_high(col3);
   if(kbd_down)
      if(!ROW_HIGH())
            kbd_down=false;
            kchar=last_key;
            last_key='\0';
      if(ROW_HIGH())
         if(input (row0))
            row=0;
            row=1;
            row=2;
            row=3;
         kbd_down = true;
            ++col;
            if(col==4)
            col=0;
   kbd_call_count=0;
return(kchar);
char k;
   k=kbd_getc();
   if(k!=0)
      if(k=='*')
         printf("%c", '*');
         printf("%c", k);
D-Kens
PostPosted: Tue Mar 25, 2008 8:34 am     Reply with quote
Thanks a lot for your code : I just began working on a project where I have to use a 4x3 keypad, and couldn't lose much time on writing code to handle it with my PIC. You made me save lots of time... Wink
fms
PostPosted: Wed Apr 02, 2008 11:11 am     Reply with quote
Really glad it did helped someone out. Worth all the debugging effort. Thanks CCS Forum and PCM programmer for the pull up version.
filjo
PostPosted: Tue Apr 29, 2008 10:07 am     Reply with quote
Hi
I try make one program using keypad 3x4 and I like use ports D I used for example "c = kbd_getc(c)" I used driver KBDD.c
but where I connect my keypad to PIC ports?
for example, I have col0, col1, col2 and row0, row1 ,row2 ,row3 but I dont know connect this, D0,D1,D2,D3,D4,D5,D6,D7...
some one can help me?
regards
PostPosted: Tue Apr 29, 2008 11:22 am     Reply with quote
My post in this thread has an explanation of the keypad connections.
http://www.ccsinfo.com/forum/viewtopic.php?t=21852
Mark's post in this thread explains how to interpret the CCS #define
statements for the pin connections in kbd.c.
http://www.ccsinfo.com/forum/viewtopic.php?t=25488
Another thread with helpful information on the keypad connections:
http://www.ccsinfo.com/forum/viewtopic.php?t=23467
filjo
PostPosted: Tue Apr 29, 2008 12:41 pm     Reply with quote
Hi PCM programmer thanks for help me ...
I configure KBDD.c in my case stay iqual because I use PIC18F452 and need connect keypad to port D.
but I my problem continue... where I connect my keypad? what is the PIN's of th e PIC?
my key pad is:
C0 | C1 | C2
R0 | 1 | 2 | 3
R1 | 4 | 5 | 6
R2 | 7 | 8 | 9
R3 | * | 0 | #
Some one can help me comple this?
C0=RD..
C1=RD..
C2=RD..
R0=RD..
R1=RD..
R2=RD..
R3=RD..
regards
PostPosted: Tue Apr 29, 2008 2:50 pm     Reply with quote
#define COL0 (1 << 5) // Pin D5
#define COL1 (1 << 6) // Pin D6
#define COL2 (1 << 7) // Pin D7
#define ROW0 (1 << 1) // Pin D1
#define ROW1 (1 << 2) // Pin D2
#define ROW2 (1 << 3) // Pin D3
#define ROW3 (1 << 4) // Pin D4
There is no connection to Pin D0.
Pins D1, D2, D3, D4 must have a 10K pull-up resistor on each pin.
filjo
PostPosted: Tue Apr 29, 2008 3:13 pm     Reply with quote
Hi
I dont know how I can thanks your help.... thanks
one question:
KBD.C for my case stay:
// Un-comment the following define to use port B
// #define use_portb_kbd TRUE
// Make sure the port used has pull-up resistors (or the LCD) on
// the column pins
#if defined(__PCH__)
#if defined use_portb_kbd
#byte kbd = 0xF81 // This puts the entire structure
#else
#byte kbd = 0xF83 // This puts the entire structure
#endif
#else
#byte kbd = 6 // on to port B (at address 6)
#else
#byte kbd = 8 // on to port D (at address 8)
#endif
#endif
#define set_tris_kbd(x) set_tris_b(x)
#else
#define set_tris_kbd(x) set_tris_d(x)
#endif
//Keypad connection: (for example column 0 is B2)
// Bx:
#ifdef blue_keypad ///////////////////////////////////// For the blue keypad
#define COL0 (1 << 2)
#define COL1 (1 << 3)
#define COL2 (1 << 6)
#define ROW0 (1 << 4)
#define ROW1 (1 << 7)
#define ROW2 (1 << 1)
#define ROW3 (1 << 5)
#else ////////////////////////////////////////////////// For the black keypad
#define COL0 (1 << 5) //PIN D5
#define COL1 (1 << 6) //PIN D6
#define COL2 (1 << 7) //PIN D7
#define ROW0 (1 << 1) //PIN D1
#define ROW1 (1 << 2) //PIN D2
#define ROW2 (1 << 3) //PIN D3
#define ROW3 (1 << 4) //PIN D4
#endif
#define ALL_ROWS (ROW0|ROW1|ROW2|ROW3)
#define ALL_PINS (ALL_ROWS|COL0|COL1|COL2)
// Keypad layout:
char const KEYS[4][3] = {{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}};
#define KBD_DEBOUNCE_FACTOR 33 // Set this number to apx n/333 where
// n is the number of times you expect
// to call kbd_getc each second
void kbd_init() {
char kbd_getc( ) {
static BYTE kbd_call_count;
static BYTE col;
BYTE kchar;
BYTE row;
kchar='\0';
if(++kbd_call_count>KBD_DEBOUNCE_FACTOR) {
switch (col) {
case 0 : set_tris_kbd(ALL_PINS&~COL0);
kbd=~COL0&ALL_PINS;
case 1 : set_tris_kbd(ALL_PINS&~COL1);
kbd=~COL1&ALL_PINS;
case 2 : set_tris_kbd(ALL_PINS&~COL2);
kbd=~COL2&ALL_PINS;
if(kbd_down) {
if((kbd & (ALL_ROWS))==(ALL_ROWS)) {
kbd_down=FALSE;
kchar=last_key;
last_key='\0';
} else {
if((kbd & (ALL_ROWS))!=(ALL_ROWS)) {
if((kbd & ROW0)==0)
row=0;
else if((kbd & ROW1)==0)
row=1;
else if((kbd & ROW2)==0)
row=2;
else if((kbd & ROW3)==0)
row=3;
kbd_down = TRUE;
} else {
++col;
if(col==3)
col=0;
kbd_call_count=0;
set_tris_kbd(ALL_PINS);
return(kchar);
I need delete firsts defines of COLs and ROWs?
but if you dont import you can explain me how you know this pinout? I like understand more about this driver.
this is for an car alarm whitch car locator... I stay make an prototype ;)
you can see more about my projects on http://filjoa.myvnc.com
regards
PostPosted: Tue Apr 29, 2008 4:12 pm     Reply with quote
No. The 'blue_keyboard' constant is not defined anywhere, so
the code for it will not be compiled. Instead, the code for the
"black keyboard" will be compiled.
Look at these statements:
The expression (1 << 5) defines a bitmask. It means 0b00000001
shifted left by 5 bit positions. It's the same as this:
#define COL0 0b00100000
Port D has 8 bits: D7 D6 D5 D4 D3 D2 D1 D0
Each bit corresponds to an i/o pin on Port D.
A bit in the following position corresponds to bit 5, which is pin D5 on Port D:
filjo
PostPosted: Tue Apr 29, 2008 6:54 pm     Reply with quote
Hi
now I understand... thanks
best regards PCM programmer, you are a crak ;)
Goto page 1, 2  Next
Page 1 of 2
