I need to know how put some chars in variables
Gendrick
View user's profile Send private message AIM Address Yahoo Messenger ICQ Number
PostPosted: Mon Feb 11, 2008 2:00 pm     Reply with quote
I´m try to use this code
strcat(Dato, Entrada[3]); //la mes escribio con 3 y 4
strcat(Dato, Entrada[4]);
strcat(Dato, Entrada[2]);
But no work fine, can somebody help me, Thanks
PostPosted: Mon Feb 11, 2008 2:32 pm     Reply with quote
You could use the strncat() function to append one character
to the 'Dato' string. Example:
The program below has the following output:
ABC342
#include <16F877.H>
#include <string.h>
char Dato[20] = {"ABC"};
char Entrada[10];
Entrada[0] = '0';
Entrada[1] = '1';
Entrada[2] = '2';
Entrada[3] = '3';
Entrada[4] = '4';
strncat(Dato, &Entrada[3], 1);
strncat(Dato, &Entrada[4], 1);
strncat(Dato, &Entrada[2], 1);
printf(Dato);
Gendrick
Thanks PCM
PostPosted: Mon Feb 11, 2008 3:24 pm     Reply with quote
Thank PCM, there are one problem, i need that the variable are empty, no : char Dato[20]= {"ABC"};
When i use only : char Dato[20];
Appear two chart like this @@ and a face, can you tell me why ?.
Thanks again
Gendrick
I realy need to get a string
PostPosted: Mon Feb 11, 2008 3:34 pm     Reply with quote
I want to get a string that coming over the RS232 and then take each value, like 234.45, 543.75, ........ I need to take the 234.45 in one variable
PostPosted: Mon Feb 11, 2008 4:21 pm     Reply with quote
Use the get_float() function. It will receive a string and convert it to
a floating point value. Example:
Run the program below. Then type in a floating point number, such as
123.45 and then press the Enter key. The program will display the
number that it received. It will be stored in the 'value' variable.
123.45 value = 123.45
777.56 value = 777.56
#include <16F877.H>
#include <stdlib.h>
#include <input.c>
float value;
   value = get_float();
   printf(" value = %7.2f \n\r", value);
Gendrick
PostPosted: Mon Feb 11, 2008 4:44 pm     Reply with quote
Thanks the problems is that the string is : 234.45, 8163.4, 957.342, 741.96, .........and i want to get every one, example K= 234.45 , M= 8163.4
x= 957.342 ...... Can you help me...
PostPosted: Mon Feb 11, 2008 4:50 pm     Reply with quote
Where do the input strings come from ? Do they come from a GPS ?
PostPosted: Mon Feb 11, 2008 5:32 pm     Reply with quote
You answered yes in a PM, so you need find some sample code written
in CCS, that will parse a NMEA-0183 GPS stream.
Here is one:
http://www.readynote.com/gpscruise/gpscruiseCCSserLCD.zip
Look at the nema.c file.
Gendrick
PostPosted: Mon Feb 11, 2008 6:16 pm     Reply with quote
For your example I can take some part of the string, but i try to convert the string part to float with K = ATOF(Dato) but K is empty.....Thank for all
