Weird result appear on hyperterminal
casandralam
PostPosted: Mon Feb 11, 2008 6:51 am     Reply with quote
hi, i'm using PIC16f877A to do rs232 data receive sample..the data input is analog,it is obtained using an analog temperature sensor that is lm35dz. when all the circuit connection done, i connected the circuit to PC through rs232 9-pin serial port.but the result appear on hyperterminal screen is some symbol such as "XXXXXXXYYYYYXXX"..it is not any integer number i expected to get before this..what does the symbol means?and how can i solve the problem to get desired integer appear on screen..
below is my source code for the program"
#include <16F877A.h>
#device adc=10
#BYTE portc=7
void main() {
int temp;
int value;
setup_port_a(ALL_ANALOG);
setup_adc_ports(AN0);
do {
value = read_ADC();
temp=value*49/100;
printf("%u",temp);
} while (TRUE);
PostPosted: Mon Feb 11, 2008 8:19 am     Reply with quote
I don't know what causes the strange symbols in Hyperterm, are they really 'X' and 'Y' characters or are those just an example?
There are some other problems in your program that need to be fixed:
1) You specify 'ADC=10', a 10-bit resolution but your 'value' variable is only 8 bits. Change 'value' to be of the type int16. This will also fix the overflow problem in 'value*49'.
2) The code for selecting the ADC channel is missing, now you are sampling a random port. Add a call to SET_ADC_CHANNEL(0).
3) For easier reading in Hyperterm you should modify the "%u" format specifier. Now all data is printed directly after each other, you can not see where one value stops and the next begins. For example use "%u\r\n" to print each value on a new line.
What is your compiler version number?
kolio
PostPosted: Mon Feb 11, 2008 8:39 am     Reply with quote
Check this out:
#fuses XT,NOWDT,NOPROTECT,NOLVP
instead of
and "%lu" format specifier instead of "%u" for 16-bit variables
good luck
