problems with timer x on 18F452
Nopnop
PostPosted: Fri Feb 08, 2008 5:30 pm     Reply with quote
hello,
we have a problem with timer.
I use 2 pics 18F452 and a FRAM from Ramtron FM24C512.
This components communicate with I2C in Multimaster Mode :
18F452 (1) (master) <--> FRAM <--> 18F452 (2) (master)
with a little program (just I2C), the Multimaster Mode function great.
No bus collision.
I can write in FRAM with pic (1) and with pic (2).
I can read in FRAM with pic (1)) and with pic (2).
And so i can receive data on pic (1) from pic (2) by the FRAM.
... etc...
But when i introduce 1 timer interrupt, I2C is stopped !
I can see pic (1) and pic (2) function, because i can see 2 flicker leds with timer...
So, Do you known any incompatibility between the I2C bus and the timer's interrupt ?
I have tested the interrupt's priority, but without result...
thanks for your idea...
(excuse me for my poor english...)
made by www.nopnop.fr
PostPosted: Fri Feb 08, 2008 7:37 pm     Reply with quote
Modify your i2c routines to disable interrupts while inside those routines.
Do this on all your fram i2c access routines, and see if it fixes the problem.
Example:
void write_fram(int16 address, int8 data)
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(0xa0);
i2c_write(address >> 8);
i2c_write(address);
i2c_write(data);
i2c_stop();
