delay_us works but not delay_ms
Dewey
PostPosted: Thu Feb 07, 2008 9:11 pm     Reply with quote
Trying to make a traffic light controller but I'm very new to this, so please be patient! I am probably doing something really dumb here, but this is driving me nuts! If I substitue us for ms in the code below it will work, although the lights flash very quickly! However, when using ms, the code stops execution at the first delay_ms. If I use us for the first delay and ms for the second, it halts at the second delay.
#include <16F877.h>
#fuses XT,NOWDT,NOPROTECT,NOPUT
#use fixed_IO(b_outputs = PIN_B1,PIN_B2,PIN_B3)
#use fixed_IO(e_outputs = PIN_E0,PIN_E1,PIN_E2)
char c;
output_low(PIN_E2); //turns off unused RE2 output
output_low(PIN_B1); //turns off red light
output_low(PIN_B2); //turns off yellow light
output_low(PIN_E0); //turns off don't walk light
output_high(PIN_B3); //turns on green light
output_high(PIN_E1); //turns on walk light
output_low(PIN_E1); //turns off walk light
for(c = 0; c < 6; c++) //loop to flash don't walk
output_high(PIN_E0); //turns on don't walk light
output_low(PIN_B3); //turns off green light
output_high(PIN_B2); //turns on yellow light
output_high(PIN_B1); //turns on red light
PostPosted: Thu Feb 07, 2008 9:18 pm     Reply with quote
#include <16F877.h>
#fuses XT, NOWDT, NOPROTECT, NOPUT, NOLVP
Add NOLVP to your fuses, as shown in bold above. Without it,
when pin B3 goes high, the PIC goes into programming mode.
The lack of NOLVP may be causing your strange symptoms.
ELCouz
PostPosted: Thu Feb 07, 2008 9:21 pm     Reply with quote
This is the problem ,, you shouldn't see a led flashing a 1000us, it should be always on (flashing but not noticeable at least).
and if delay_ms(1000); dont work... probably it work but very slowly(ex: wrong osc. conf ? )...
what is your XT osc. you are using ?
EDIT
I second that!
Best Regards,
Laurent
Dewey
PostPosted: Thu Feb 07, 2008 9:46 pm     Reply with quote
I tried NOLVP added to fuses and it did not help. It will work with us but not ms. When in us mode, I was trapping on it with a logic analyzer - that was how I knew it was working. Also, like I said, I can use us for the first delay and it will get past that and hang at the next delay that is ms. The osc freq is 4MHz - verified with a scope.
PostPosted: Thu Feb 07, 2008 9:50 pm     Reply with quote
Post your compiler version. It's a 4-digit number in this format: x.xxx
You can find it at the top of the .LST file, which will be in your project
directory.
Dewey
PostPosted: Thu Feb 07, 2008 9:52 pm     Reply with quote
4.038
PostPosted: Thu Feb 07, 2008 9:54 pm     Reply with quote
Also post a description of the external circuits that are connected to
your i/o pins. Give the component values, where applicable.
Dewey
PostPosted: Fri Feb 08, 2008 8:24 pm     Reply with quote
Got it working! After doing some searching on the net, I found a function similar to this:
void delay_zs(int16 t)
do
delay_us(65500);
} while(--t);
The function gives me about .5mS of delay, so I just call the function (which I named delay_zs just to prevent any possible conflict with the built in ms function) 20,000 times to get about 10 seconds of delay. Crude, but effective! Thanks for all your help!
