'AT' commands used in a C program
aesli
PostPosted: Thu Jan 31, 2008 3:03 pm     Reply with quote
Hi guys
does anybody have any idea how I have to implement my AT commands in the C program that it is possible to communicate with a Zigbee node?
I use a PIC to send AT commands to a Zigbee node but there are some problems with the C program.
this program just should send a AT command to the node which so turns on the LED on the node
#include "test.h"
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
char at_openPort4[]={"ats0d4=1\r"};
char at_flashLedOn[]={"ats0f4=0\r"};
char at_flashLedOff[]={"ats0f4=1\r"};
   delay_ms(2000);
   puts(at_openPort4);        //set I/O4 as an output
   delay_ms(5000);
   puts(at_flashLedOn);         //turn on the LED
cheers for any help
N.D.
KamPutty
PostPosted: Thu Jan 31, 2008 3:47 pm     Reply with quote
Hey ND,
Do you need to send a <CR> also with the <LineFeed>
char at_openPort4[]={"ats0d4=1\r\n"};
~Kam (^8*
PostPosted: Thu Jan 31, 2008 7:39 pm     Reply with quote
I'm also missing the definition of the RS232 parameters. Most likely you are now sending at the wrong baudrate.
Change the baudrate and pin numbers according to your hardware.
At the end of your program add an infinite loop. Now when your program reaches the end it executes a sleep instruction by which the last character in the UART is never transmitted.
  while (TRUE)
     // Loop forever
Foppie
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
PostPosted: Fri Feb 01, 2008 1:43 am     Reply with quote
In addition of the above replies. You might have to send a string to put the zigbee module in at mode. The zigbee modules I use require "+++" before it enters AT mode.
aesli
PostPosted: Fri Feb 01, 2008 6:19 am     Reply with quote
thanks for the answers
the thing is if I am using hyper terminal every thing is working fine.
But looks like I don't get the commands through the C program
thats the fuses and rs 232 configuration I'm using for the program above
#include <18F4520.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES NOPROTECT                //Code not protected from reading
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NOSTVREN                 //Stack full/underflow will not cause reset
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES PBADEN                   //PORTB pins are configured as analog input channels on RESET
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use rs232(baud=19200,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
if it work with hyper terminal do I have to use the string "+++" like foppie says, and how do you implement it in your C code?
cheers for help
N.D.
Foppie
PostPosted: Fri Feb 01, 2008 6:58 am     Reply with quote
If you don't need to send the "+++" in hyperterminal then you don't need it in your PIC as well.
Have you tried to connect your PIC to a PC and look if the strings are transmitted by the PIC?
aesli
PostPosted: Fri Feb 01, 2008 8:07 am     Reply with quote
if I connect the rs232 to pc it sends the AT command while I'm using hyper terminal. But it doesn't work with the zigbee node.
May be I start to build up every thing on a bread board. I'm using at the moment the CCS development board.
Thanks for the help though.
I'll keep trying Smile
PostPosted: Sun Apr 13, 2008 12:02 am     Reply with quote
is it possible to send strings in hyperterminal to PIC? or its just sending characters to PIC but not strings of characters?
