Comparator output always low
bruce
PostPosted: Tue Jan 29, 2008 3:17 pm     Reply with quote
I am using the PCWH 4.065 to program a PIC18LF2620. I am using the comparator and when I read the comparator register CMCON (bit 6) C1OUT I can see it changing state from 1 to 0 to 1 etc… but when I measure Pin 6 C1OUT, it always reads zero volts.
I am using fast I/O with set_tris and have the pin configured as an output. I can toggle the output with output_toggle(PIN_A4) - just to test the pin – and I can measure pin 6 with a DVM and see it changing state. I have these other setups:
port_b_pullups(TRUE);
setup_adc_ports(AN0_TO_AN4|VSS_VREF);
setup_adc(ADC_CLOCK_DIV_64|ADC_TAD_MUL_20);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(0x8F); //enabled, external, noSync
setup_ccp1(CCP_OFF);
setup_ccp2(CCP_OFF);
setup_comparator(A0_VR_A1_VR|CP1_INVERT);
setup_vref(VREF_HIGH|VREF_COMP|6); //level
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
SET_TRIS_A( 239 ); //set port direction, 1=input (239) 0xef
SET_TRIS_B( 193 ); //set port direction, 1=input (193) 0xc1
SET_TRIS_C( 219 ); //set port direction, 1=input (195) 0xdb
OUTPUT_A(0);
OUTPUT_B(32);
OUTPUT_C(36);
CCS tech support has been looking at this for about a week, and they think that it could be a device header file issue. However, I was wondering… Has anyone here seen this “pin 6 is always low” problem before and solved it?
Thanks,
Bruce
PostPosted: Wed Jan 30, 2008 5:38 am     Reply with quote
Comparator mode 6 doesn't connect the output of a comparator to
pin RA4. Only modes 1, 3, and 5 do so.
Look at the schematics of the comparator modes, in this figure in
the 18F2620 data sheet:
FIGURE 20-1: COMPARATOR I/O OPERATING MODES
bruce
PostPosted: Wed Jan 30, 2008 8:05 am     Reply with quote
Wow, I didn’t notice that. I had a suspicion I was doing something wrong and it wasn’t the compiler because this is the first time I have used the comparator… I am so glad I tried this forum.
I want to use the CVref feature (only available in mode 6) so it looks like I have to monitor the CMCON register and output the state of the C1OUT bit using output_bit via poll or interrupt.
Thanks,
Bruce
PostPosted: Wed Jan 30, 2008 8:46 am     Reply with quote
Or, if you can afford the pins, use mode 5, and connect RA2 to RA3. Program the comparator reference to give an output on RA2, and 'voila'. Smile
bruce
PostPosted: Wed Jan 30, 2008 2:34 pm     Reply with quote
Yes, that method uses too many pins. I only need one comparator. I could use mode 1, but the final blow to that method is that I am using Vref (needs to be 3.0V, Vdd is not reliable) for the ADC and the Comparator Voltage Reference Module.
Thanks anyway…
Bruce
