__attribute__ mechanism
fedetouz
PostPosted: Sat Jan 26, 2008 5:52 pm     Reply with quote
i translating a code from other platform to CCS, i have one problem, i can't compile __attribute__ syntax.
for example:
typedef struct
  uint8 abc;
  union
    uint8 pay[ 100 ];
    TX64 tx64;
    TX16 tx16;
    TXStatus txStatus;
    RX64 rx64;
    RX16 rx16;
    ATCommand Command;
    ATCommandResponse Response;
    IO64 io64;
    IO16 io16;
  uint8 crc;
  uint8 *dataPtr;
  int rxState;
  int length;
  int index;
} __attribute__((packed)) XPacket;
PostPosted: Sat Jan 26, 2008 11:07 pm     Reply with quote
I am translating a code from other platform to CCS
If you want help, you need to tell us what is the other platform (and
compiler).
